[Nek5000-users] Conj HT problem w/ latest repo
Thu Jun 24 11:01:30 CDT 2010
I am having a problem running a conjugate heat transfer test case. I was able to get it to run with no problems on the repo I had (which I checked to be early 400's, 410 I believe, around April).
I checked out the latest repo version and am now getting NaN values for Helmhotlz VEL X, Y, & Z. A few lines are shown below for Step 1. I have attached my case file. I am not sure what the issue is, nothing has changed other than the repo version I am now using. Thanks for any help.
- Michael M.
Starting time loop ...
DT/DTCFL/DTFS/DTINIT 0.100E-01 0.293-316 0.247-322 0.100E-01
Step 1, t= 1.0000000E-02, DT= 1.0000000E-02, C= 0.000 0.0000E+00 0.0000E+00
Solving for heat
Solving for fluid
Temperature/Passive scalar solution
1.00000000000000002E-008 p22 1 2
New CG1-tolerance (RINIT*epsm) = 1.87930932840962565E-011 2.07249891917608222E-022
1 1 Helmholtz TEMP F: 1.8793E+02 1.0000E-08 1.0000E-01 1.0000E+02
1 2 Helmholtz TEMP F: 5.8007E+01 1.0000E-08 1.0000E-01 1.0000E+02
1 3 Helmholtz TEMP F: 1.9356E+01 1.0000E-08 1.0000E-01 1.0000E+02
1 4 Helmholtz TEMP F: 7.5782E+00 1.0000E-08 1.0000E-01 1.0000E+02
1 5 Helmholtz TEMP F: 2.7995E+00 1.0000E-08 1.0000E-01 1.0000E+02
1 6 Helmholtz TEMP F: 9.2434E-01 1.0000E-08 1.0000E-01 1.0000E+02
1 7 Helmholtz TEMP F: 3.6237E-01 1.0000E-08 1.0000E-01 1.0000E+02
1 8 Helmholtz TEMP F: 1.1048E-01 1.0000E-08 1.0000E-01 1.0000E+02
1 9 Helmholtz TEMP F: 3.2726E-02 1.0000E-08 1.0000E-01 1.0000E+02
1 10 Helmholtz TEMP F: 1.3437E-02 1.0000E-08 1.0000E-01 1.0000E+02
1 11 Helmholtz TEMP F: 4.3238E-03 1.0000E-08 1.0000E-01 1.0000E+02
1 12 Helmholtz TEMP F: 1.6986E-03 1.0000E-08 1.0000E-01 1.0000E+02
1 13 Helmholtz TEMP F: 6.5007E-04 1.0000E-08 1.0000E-01 1.0000E+02
1 14 Helmholtz TEMP F: 2.0208E-04 1.0000E-08 1.0000E-01 1.0000E+02
1 15 Helmholtz TEMP F: 6.5695E-05 1.0000E-08 1.0000E-01 1.0000E+02
1 16 Helmholtz TEMP F: 2.5632E-05 1.0000E-08 1.0000E-01 1.0000E+02
1 17 Helmholtz TEMP F: 8.2880E-06 1.0000E-08 1.0000E-01 1.0000E+02
1 18 Helmholtz TEMP F: 3.2190E-06 1.0000E-08 1.0000E-01 1.0000E+02
1 19 Helmholtz TEMP F: 1.1074E-06 1.0000E-08 1.0000E-01 1.0000E+02
1 20 Helmholtz TEMP F: 3.1244E-07 1.0000E-08 1.0000E-01 1.0000E+02
1 21 Helmholtz TEMP F: 1.2354E-07 1.0000E-08 1.0000E-01 1.0000E+02
1 22 Helmholtz TEMP F: 4.2673E-08 1.0000E-08 1.0000E-01 1.0000E+02
1 23 Helmholtz TEMP F: 1.5376E-08 1.0000E-08 1.0000E-01 1.0000E+02
1 24 Helmholtz TEMP F: 6.1053E-09 1.0000E-08 1.0000E-01 1.0000E+02
1 Hmholtz TEMP: 23 6.1053E-09 1.8793E+02 1.0000E-08
1 1.0000E-02 3.3134E-01 Heat done
1.00000000000000002E-008 p22 1 1
1 1 Helmholtz VELX F: NaN 1.0000E-08 1.0000E-02 1.0000E+02
1 2 Helmholtz VELX F: NaN 1.0000E-08 1.0000E-02 1.0000E+02
1 3 Helmholtz VELX F: NaN 1.0000E-08 1.0000E-02 1.0000E+02
1 4 Helmholtz VELX F: NaN 1.0000E-08 1.0000E-02 1.0000E+02
1 5 Helmholtz VELX F: NaN 1.0000E-08 1.0000E-02 1.0000E+02
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100624/77d8dbc5/attachment.html>
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100624/77d8dbc5/attachment.tar>
