[Nek5000-users] Periodic BC & Genmap issue
Mon Jun 21 11:07:45 CDT 2010
I am running into an error when trying to use genmap. I believe it has to do with the periodic boundary conditions I have set up. I have checked the elements, and faces and indeed they are given correctly. This leads me to believe that there may be an issue with genmap. I have attached the rea file. This was to test the periodic faces for this geometry. The output is shown below, thanks for any help with this.
- Michael M.
Here is the output:
test
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
.2
reading .rea file data ...
start locglob_lexico: 8 60 480 0.20000000000000001
locglob: 1 1 480
locglob: 2 27 480
locglob: 3 42 480
locglob: 1 168 480
locglob: 2 168 480
locglob: 3 168 480
locglob: 1 168 480
locglob: 2 168 480
locglob: 3 168 480
done locglob_lexico: 168 168 480 4
start periodic vtx: 60 168
1 3 5 3 3.66325334E-04 1 shift
3 4 4 Matrix: x0
1 x0 1.7389E-03 2.8363E-03 2.8363E-03 1.7389E-03
2 x0 -6.9998E-02 7.0969E-02 6.9026E-02 -6.9998E-02
3 x0 2.0879E-02 2.0879E-02 -2.0937E-02 -2.0821E-02
4 x0 8.3935E-03 8.0685E-03 -2.4856E-02 8.3935E-03
1 4 4 Matrix: x1
1 x1 1.7389E-03 1.7389E-03 2.8351E-03 2.8351E-03
2 x1 -7.0107E-02 -7.0107E-02 6.8930E-02 7.1286E-02
3 x1 2.0876E-02 -2.0824E-02 -2.0927E-02 2.0876E-02
4 x1 8.3867E-03 8.3867E-03 -2.4834E-02 8.0608E-03
3 4 4 Matrix: z0
1 z0 1.7389E-03 2.8363E-03 2.8363E-03 1.7389E-03
2 z0 -1.2500E+00 -1.1090E+00 -1.1110E+00 -1.2500E+00
3 z0 0.0000E+00 0.0000E+00 -4.1816E-02 -4.1700E-02
4 z0 -5.0620E-01 -5.0653E-01 -5.3945E-01 -5.0620E-01
1 4 4 Matrix: z1
1 z1 1.7389E-03 1.7389E-03 2.8351E-03 2.8351E-03
2 z1 -1.2500E+00 -1.2500E+00 -1.1110E+00 -1.1086E+00
3 z1 0.0000E+00 -4.1700E-02 -4.1803E-02 0.0000E+00
4 z1 4.9380E-01 4.9380E-01 4.6058E-01 4.9347E-01
3 4 3 1.00000000E-03 7.09692500E-02 abort: FACE MATCH FAIL
1 3 5 7.09692500E-05 3.66325334E-04 abort: FACE MATCH FAIL
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100621/aba96dc9/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100621/aba96dc9/attachment.bin>
