[Nek5000-users] New Recycling BC method?
Wed Jun 16 21:58:53 CDT 2010
Michael,
got it...
I should be able to send a fix by morning that will work for any
instances in which slab at location A has same (arbitrary) topology
orientation as slab at location B, as is the case in the example
you sent.
This won't cover all cases but would likely cover 90%.
hth,
Paul
On Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Paul,
> See attached for the rea. Thanks,
> Michael
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Wednesday, June 16, 2010 9:47:29 PM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] New Recycling BC method?
> 960 is ok On Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Paul, > > > > The rea I have now from matlab/gambit has 960 elements.  Do you want me to create another, smaller rea that may make it easier to work with? > > > > The geometry by the way is a simple pipe flow. > > > > - Michael > > > ----- Original Message ----- > From: nek5000-users at lists.mcs.anl.gov > To: nek5000-users at lists.mcs.anl.gov > Sent: Wednesday, June 16, 2010 9:39:59 PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New Recycling BC method? > > Hi Micheal, I agree completely that it's best to avoid mix & match meshing. If you want to send me a gzipped .rea file produced by Gambit, I can take a look and see if I have any ideas. Paul On Wed, 16 Jun 2010, nek5000-users at lists.mcs.anl.gov wrote: > > > Hi Paul, > > > > Thanks for the reply.  The reason for the interest is due to the Gambit to Nek matlab code. We have had great success importing complex geometries with it, but no
 w we run into the issue of the recycling boundary condition.  Gambit's ordering of the elements is not always consistent which makes it impossible to use the current technique. > > > > Our solution was to create the portion that has the recycling in prex and then merge it with the complex part created in Gambit. However, this is proving to be very time consuming and troublesome (Element Mismatch Errors).  So, to avoid this I would like to come up with a new recycling method that does not depend on the elements being in a specific order. My u nderstanding is that the current method looks at the inflow, counts a certain number of elements up, copies this outflow from face 6 and puts it back into the inflow face 5. > > > > What I would like to do is replace how the inflow plane is connected to the outflow plane. My idea was to use the connectivity matrix to figure out what the element numbers and outflow faces are at a certain distance away from the inflow plane, and use t
 hese faces to connect.  The cross-section for the inflow and outflow plane would be the same, but you couldn't necessarily say that it is located, say inflow + 30 elements for example, OR that the outflow and inflow faces are all the same (face 5 for inflow, face 6 for outflow for example).  > > > > Do you think this is possible? In a way, you would be creating a new connectivity matrix that governs the recycling BC. > > > > Thanks! > > - Michael M. > > > ----- Original Message ----- > From: nek5000-users at lists. mcs . anl .gov > To: nek5000-use rs at lists. mcs . anl .gov > Sent: Wednesday, June 16, 2010 9:08:00 PM GMT -06:00 US/Canada Central > Subject: Re: [Nek5000-users] New Recycling BC method? > > Hi Michael, Access to the connectivity array wouldn't help in this case, given that the recycling bc needs to establish a _new_ connectivity that has nothing to do with the existing one. The examples use this approach of establishing a new connectivity. I'm confident that we ca
 n make the existing approach for any mesh that can legitimally employ the recycling bc - i.e., any mesh that has the same cross-sectional distribution of elements at the two planes of interest. An alternative is to use the general purpose interpolation routines. There may (or may not) be a performance issue -- we're looking into this w/ the help of a summer student. Please let me know if I can assist you w/ your specific case. Paul > I am still trying to figure this idea out, but I think I would need to > access the connectivity/boundary condition information that is contained > in the rea file. Does anyone know the array, or what to call in order to > access this in the usr file?  Thanks again for a ny help! > > > > - Michael M. > > > ----- Original Message ----- > From: nek5000-users at lists. mcs . anl .gov > To: " Nekton User List" > Sent: Tuesday, June 15, 2010 9:02:00 PM GMT -06:00 US/Canada Central > Subject: [Nek5000-users] New Recycling BC method? > > > > > Hello All,
  > > > > I am wondering if there is another technique to set up a recycling boundary condition that does not depend on the elements being in a certain order (say based on element coordinates for instance)?   I would like to pick the recycling plane based on a given offset distance rather than a number of elements. > > > > Also, the outflow plane faces may not all necessarily be face 6 (and face 5 for the inflow plane). > > > > I have tried going through the examples where a recycling BC is used however I am finding it difficult to understand as my knowledge of Fortan is still growing. Thanks for any help anyone can provide with this idea. > > > > Regards, > > Michael M. > > >   > ___________________ ____________________________ Nek5000-users mailing list Nek5000-users at lists. mcs . anl .gov https ://lists. mcs . anl .gov/mailman/ listinfo /nek5000-users > _______________________________________________ Nek5000-users mailing list Nek5000-users at lists. mcs . anl .gov https :/
 /lists. mcs . anl .gov/mailman/ listinfo /nek5000-users > _______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
