[Nek5000-users] Gradients in an object : Few queries for parallel setting.
Thu Jun 10 10:58:03 CDT 2010
Hello,
I am trying to find gradients and the coordinates of an object in nek. I
used set_obj routine to fix my walls as object and also wrote a routine that
is
similar to the drag_calc routine to dump out the co-ordinates and the
gradients on the object. This code works fine for a serial setting while for
parallel setting,
only a part of the object coordinates are dumped out. I suspect that I have
not included a few routines that would gather information from all the
processors.
It would be great if you could throw in some suggestions that would set it
to work in parallel setting. I have pasted a part of the usrchk routine
herewith :
<code>
       DIMENSION TEMP1(lz1**2) ! Stores the du/dy of all the GLL points in
one face (in the object)
       parameter(lt=lx1*ly1*lz1)
       common /scrns/         pm1(lx1,ly1,lz1,lelv)
     $,vxx(lx1,ly1,lz1,lelv),vxy(lx1,ly1,lz1,lelv),vxz(lx1,ly1,lz1,lelv)
     $,vyx(lx1,ly1,lz1,lelv),vyy(lx1,ly1,lz1,lelv),vyz(lx1,ly1,lz1,lelv)
       common /scruz/
     $ vzx(lx1,ly1,lz1,lelv),vzy(lx1,ly1,lz1,lelv),vzz(lx1,ly1,lz1,lelv)
     $,one(lx1,ly1,lz1,lelv)
      if (istep.eq.0) then
         call set_obj                   ! objects for surface integrals
      endif
       call izero(TEMP1,lz1**2) ! Initializing to zeros.
        open(unit=103,file='coord.txt') ! few files for post-processing
        open(unit=104,file='elenos.txt')
       CALL DUDXYZ (vxx,vx,RXM1,SXM1,TXM1,JACM1,1,1)
       CALL DUDXYZ (vxy,vx,RYM1,SYM1,TYM1,JACM1,1,1)
       CALL DUDXYZ (vxz,vx,RZM1,SZM1,TZM1,JACM1,1,1)
       ntot1 = nx1*ny1*nz1*nelv
       call rone (one,ntot1)
c------------------------------------------------------------------
      DO 100 II=1,NHIS
         IF (HCODE(10,II).NE.'I') GOTO 100
         IOBJ   = LOCHIS(1,II)
         MEMTOT = NMEMBER(IOBJ)
         IF (HCODE(1,II).NE.' ' .OR. HCODE(2,II).NE.' ' .OR.
     $       HCODE(3,II).NE.' ' ) THEN
            IFIELD = 1
            DO 50 MEM=1,MEMTOT
               ISK   = 0
               IEG   = OBJECT(IOBJ,MEM,1)
               IFC   = OBJECT(IOBJ,MEM,2)
c               IF (GLLNID(IEG).EQ.NID) THEN
C                 This processor has a contribution
                  IE = GLLEL(IEG)
                   write(104,*)ieg,ie,gllnid(ieg),nid
       call dotabf(TEMP1,vxy,one,ifc,ie) ! subroutine that multiplies vxy by
one and stores in temp for that element
      CALL DSSET(NX1,NY1,NZ1)
      IFACE  = EFACE1(IFC)
      JS1    = SKPDAT(1,IFACE)
      JF1    = SKPDAT(2,IFACE)
      JSKIP1 = SKPDAT(3,IFACE)
      JS2    = SKPDAT(4,IFACE)
      JF2    = SKPDAT(5,IFACE)
      JSKIP2 = SKPDAT(6,IFACE)
      I = 0
      DO 110 J2=JS2,JF2,JSKIP2
      DO 110 J1=JS1,JF1,JSKIP1
         I = I+1
         if(istep.eq.2) then
         write(103,18)xm1(J1,J2,1,ie),ym1(J1,J2,1,ie),zm1(J1,J2,1,ie)
     $ ,TEMP1(I)
   18  format(1x,4(E14.7,1X))
         endif
  110 CONTINUE
c            ENDIF
   50       CONTINUE
</code>
If the rea/usr file is needed, please let me know. Thanks.
Thanks
Shriram
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100610/060d6191/attachment.html>
