[Nek5000-users] to Michael--> Nek5000 & Gambit, blocked file
Sun Jun 6 08:58:01 CDT 2010
Frank,
It is trying to extract information about the boundary conditions from
the neu file, there is most likely an error here.
Attach the Neu file and I'll have a look
- Michael
On Jun 5, 2010, at 11:28 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Michael,
> I have been running your code and have hit the error below.
> Unfortunately, I don't ever use Matlab.
> Cheers,
> Frank
> ELEM & PTS MATRIX RESTURCTURE:    STARTED ****
> ??? Index exceeds matrix dimensions.
> Error in ==> readingNEU2 at 99
>        ElmF(f+1:f+n1(i),1)=BC1m(f+1:f+n1(i),1);
> Error in ==> rea_write at 17
> [Npts,Nelm,Elem,ElemMidPts1,Pts,Elem1,ElmF,...
> On Fri, 2010-06-04 at 18:42 -0500, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Hi Frank,
>> This is achieved by the step 2 in the list I gave:  You must set the
>> edge nodes from 2 to 3. Alternatively you could set the face from 4
>> to
>> 8 or the volume from 8 to 20 nodes. The extra nodes that gambit
>> throws
>> because of this are the midpoints.  For Nekton, the recent midside
>> node support feature which fits a parabola through the two corner
>> points and midpoint of the element side is where this comes into
>> play.
>> So all you need to do is make sure you have set the mesh nodes as
>> above, and the matlab code does the rest. It separates the element's
>> corner nodes from the midpoint nodes. The midpoint nodes are written
>> into the curved side section of the the REA, whereas the corner
>> points
>> are written into the Mesh data section. So...The matlab code only
>> uses
>> the flag 'm' for curved side data.
>> Also, in the inputs section you can specify a maximum radius for
>> consideration. The code will check each edge's corner and midpoints
>> and determine the radius curvature. If it is too large it considers
>> it
>> a straight edge and moves on.
>> Hope this helps,
>> Michael
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Friday, June 4, 2010 6:24:06 PM GMT -06:00 US/Canada Central
>> Subject: Re: [Nek5000-users] to Michael--> Nek5000 & Gambit, blocked
>> file
>> Hi Michael,
>> Thanks very much for the code.  One question concerning the curved
>> sides: if one had a 3D cylindrical pipe grid from Gambit, how would
>> the
>> curvature of the outside (boundary) faces of the grid be set in your
>> code?
>> Cheers,
>> Frank
>> On Thu, 2010-06-03 at 21:13 -0500, nek5000-users at lists.mcs.anl.gov
>> wrote:
>>> Hi Frank,
>>> Try the attached.
>>> - Michael
>>> Sent: Thursday, June 3, 2010 9:01:14 PM GMT -06:00 US/Canada Central
>>> Subject: [Nek5000-users] to Michael--> Nek5000 & Gambit, blocked
>> file
>>> Hello Michael,
>>> It seems that you sent an email with a *.zip attachment, which due
>> to
>>> a
>>> spam filter, got blocked.  If it is renamed to say *.zipp, then it
>>> should get through.
>>> Cheers,
>>> Frank
>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>> Technische Universität Wien (Technical University of Vienna)
>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of F
>>> luid
>>> Mechanics and Heat Transfer)
>>> Resselgasse 3
>>> 1040 Wien
>>> Tel: +4315880132232
>>> Fax: +4315880132299
>>> Cell:+436765203470
>>> fmuldoo (skype)
>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fl
>> uid
>> Resselgasse 3
>> 1040 Wien
>> Tel: +4315880132232
>> Fax: +4315880132299
>> Cell:+436765203470
>> fmuldoo (skype)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
