[Nek5000-users] to Michael--> Nek5000 & Gambit, blocked file
Fri Jun 4 18:55:03 CDT 2010
>From the previous email:
1.    Set Solver type to GENERIC
2.   When Meshing, make sure the edge node count is 3 (for midpoints).  This should make the face count 8 and the volume count 20 nodes.
      This setting is necessary to take advantage of Nektons mid side node support.
3.   Use the zones to label faces as Boundary conditions. Select multiple faces if you like. Since the solver is set to generic, just call the BC
anything you like, "Inlet" for example.  The Matlab code will ask you "What did you mean by Inlet", where you would input 'v' for a fortran
velocity input.  If it is a thermal problem (TBC = 1 in the inputs in rea_write), it will ask for the momentum and thermal BC.  In gambit, any
face that is not labeled with a BC type is assumed to be a Wall.
NOTE:   The Mesh must be HEX & Edge node count 3!...  ONLY works for 3D cases!
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, June 4, 2010 6:51:34 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] to Michael--> Nek5000 & Gambit, blocked file
Hi Michael,
What is the "list" you are referring to?
Cheers,
Frank
On Fri, 2010-06-04 at 18:42 -0500, nek5000-users at lists.mcs.anl.gov
wrote:
> Hi Frank,
> This is achieved by the step 2 in the list I gave:  You must set the
> edge nodes from 2 to 3. Alternatively you could set the face from 4 to
> 8 or the volume from 8 to 20 nodes. The extra nodes that gambit throws
> because of this are the midpoints.  For Nekton, the recent midside
> node support feature which fits a parabola through the two corner
> points and midpoint of the element side is where this comes into
> play.
> So all you need to do is make sure you have set the mesh nodes as
> above, and the matlab code does the rest. It separates the element's
> corner nodes from the midpoint nodes. The midpoint nodes are written
> into the curved side section of the the REA, whereas the corner points
> are written into the Mesh data section. So...The matlab code only uses
> the flag 'm' for curved side data.
> Also, in the inputs section you can specify a maximum radius for
> consideration. The code will check each edge's corner and midpoints
> and determine the radius curvature. If it is too large it considers it
> a straight edge and moves on.
> Hope this helps,
> Michael
> From: nek5000-users at lists.mcs.anl.gov
> Sent: Friday, June 4, 2010 6:24:06 PM GMT -06:00 US/Canada Central
> file
> Hi Michael,
> Thanks very much for the code.  One question concerning the curved
> sides: if one had a 3D cylindrical pipe grid from Gambit, how would
> the
> curvature of the outside (boundary) faces of the grid be set in your
> code?
> Cheers,
> Frank
> On Thu, 2010-06-03 at 21:13 -0500, nek5000-users at lists.mcs.anl.gov
> wrote:
> > Hi Frank,
> > Try the attached.
> > - Michael
> > Sent: Thursday, June 3, 2010 9:01:14 PM GMT -06:00 US/Canada Central
> > Subject: [Nek5000-users] to Michael--> Nek5000 & Gambit, blocked
> file
> > Hello Michael,
> > It seems that you sent an email with a *.zip attachment, which due
> to
> > a
> > spam filter, got blocked.  If it is renamed to say *.zipp, then it
> > should get through.
> > Cheers,
> > Frank
> > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> > Technische Universität Wien (Technical University of Vienna)
> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> > Mechanics and Heat Transfer)
> > Resselgasse 3
> > 1040 Wien
> > Tel: +4315880132232
> > Fax: +4315880132299
> > Cell:+436765203470
> > fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100604/0ff63822/attachment.html>
