[Nek5000-users] "vnormal_desired = ?" for turbulent outflow boundary condition
Fri Jun 4 09:15:29 CDT 2010
Hello,
I am running a LES case for backward facing step with Re=28000. The
incoming mean velocity is 1.0. I am having trouble with setting the
turbulent outflow boundary condition.
I am using the fill_div(usrdiv) subroutine. The "vnmo_desired = 0.05" for
this case and for this value the simulation does not look right. As seen
in the two figures for instantaneous and average x-velocity countour
pictures.
Instantaneous x-vel:
http://www2.uic.edu/~hkanch1/x-vel-instantaneous.jpeg
Average x-vel:
http://www2.uic.edu/~hkanch1/x-vel-avg0000.jpeg
For a value of "vnmo_desired" less than 0.02, the simulation blows up. Is
there a way I can estimate the value of "vel_normal desired". The incoming
channel height is 4.0 and mean velocity is 1.0. The outflow channel height
is 5.0. The value of "dmax = 1.488", this is used in calculation "cdiv".
Attached is the *.usr file for this case.
Any help will be appreciated.
Harish.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100604/86d8821f/attachment.obj>
