[Nek5000-users] Uservp, eddy diffusivity and explvis
Sun Jul 25 15:14:53 CDT 2010
thanks for clarifying, I'll keep it turned on.
I tried both IFCHAR true and false, the error is the same.
I also tried to reproduce the error on a coarser geometry, similar Re
and geometric features, but I couldn't - adding some diffusivity while
USERVP and explvis are true worked. So I tend to think it is some
specialty within my simulation.
What helps, however, is to switch from PN-PN to PN-PN2. Then, the
simulation behaves OK.
So I'll work with that for now.
Markus
nek5000-users at lists.mcs.anl.gov wrote:
> Ok if is changing you have to set ifexplvis = .true.
> Are you using IFCHAR=.true.?
> On Jul 20, 2010, at 1:56 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> No, it's changing in time and space since it's computed with an eddy diffusivity model. But when I turn ifexplvis on, the simulation crashes after very few time steps due to crazy velocities - even though I don't change viscosity for trial purposes.
>> Markus
>>> Is your viscosity constant?
>>> Stefan
>>> On Jul 20, 2010, at 12:18 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi,
>>>> can I leave "ifexplvis = .false." when doing a nek simulation with user defined viscosity and PN/PN?
>>>> Markus
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
