[Nek5000-users] New Recycling BC based on interpolation
Fri Jul 23 15:41:38 CDT 2010
Michael,
try now and see if it works...
Paul
On Fri, 23 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Aleks and Stephan,
> I have a question directly related to this.  I would like to use the hpts() routine for my conjugate case, however like Markus mentioned, there is no support for a conjugate case at the moment.  Were ya'll able to fix this?
> Thanks,
> Michael
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Monday, July 19, 2010 8:38:05 AM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] New Recycling BC based on interpolation
> Hi Aleks,
> what was your plan to fix it?
> In fact I think findpts_eval() should work as is but there is no-err handling if you try to interpolate on a point in the solid using an input field based on the v-mesh.
> Ok we don't need an err-handling at the moment. You'll get a ZERO value back although it is an invalid point for an input field based on the v-mesh.
> Why is that?
> At the moment, all field arrays have the same layout and size (lx1,ly1,lz1,lelt) independent of the mesh type (v or T). We simply set all values of a v-variable to ZERO for iel>nelv and we don't touch these segments later on.
> Stefan
> On Jul 19, 2010, at 3:25 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Stefan,
>> Yes, we have noticed you changed the interface -- and the latest version of Recycling Bcs w/ interpolation works for the latest repo version (548).
>> Eventually we can get it working for CHT too.
>> Best,
>> Aleks
>> Sent: Monday, July 19, 2010 7:05:21 AM GMT -06:00 US/Canada Central
>> Hi Guys,
>> I worked on the interpolation wrappers over the last months and I am not sure if the new recycling BC is compatible to the latest repo-version?
>> Paul/Aleks: can you comment on that?
>> Now, in the case of CHT (nelgt>nelgv) findpts_eval() won't work! I guess the size of the input field has to match the dimensions of XM1,YM1,ZM1 specified in inpts_setup().
>> I will talk to James if we can come up with an easy fix for that.
>> Stefan
>> -----Original Message-----
>> From: nek5000-users-bounces at lists.mcs.anl.gov on behalf of nek5000-users at lists.mcs.anl.gov
>> Sent: Sun 7/18/2010 13:53
>> Hi Markus,
>> this stuff is all brand new and you are in the leading edge
>> of the testing (since none of us are exercising it in our
>> own applications), so there will be a bit of development as
>> we go forward.  We can readily fix interp_v (but I advise
>> using it now in order to identify other issues).
>> interpv is _much_ more expensive than gs_op.
>> However, if one takes 1 part in a million and the other 1
>> part in 10,000 of the run time, then both are negligible.
>> So the question is really relative to the wall-clock time.
>> Paul
>> On Sun, 18 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi,
>>> no, I haven't done any speed comparison. So I take it there is no principal
>>> difference between intpts and gs_op in terms of computational cost?
>>> I was referring to line 172f of the new recycling BC code:
>>>     if (nelgt.ne.nelgv) call exitti
>>>    $   ('ABORT: interp_v() nelgt.ne.nelgv not yet supported!$',nelgv)
>>> and was wondering if that is due to something in intpts and if so, if the
>>> same constraint would apply to findpts.
>>> Markus
>>>> Hi Markus,
>>>> I don't know why this wouldn't work for nelgt > nelgv.
>>>> I would say we don't know the performance hit yet - I think
>>>> someone is looking into this question.  Performance will of course vary
>>>> significantly from problem to problem and platform
>>>> to platform.   I suspect that it should not be a major hit ---
>>>> have you observed otherwise?
>>>> Paul
>>>> On Sat, 17 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi Aleks,
>>>>> thanks for the code, I looked over it and have two questions:
>>>>> -at some point, it is mentioned that this method does not work if
>>>>> nelgt>nelgv. Why is that? I am asking because this will be applied to a
>>>>> conjugate HT problem (although the recycling part is purely concerning
>>>>> flow+convection). Will this problem also occur when only findpts is used
>>>>> instead of intpts?
>>>>> -is there a performance difference between calling intpts as opposed to
>>>>> gs_op (as is done in the turbJet example) every time step for large scale
>>>>> production runs? The latter is what I used in my version.
>>>>> Thanks,
>>>>> Markus
>>>>>> Hi Michael and Markus,
>>>>>> Here is a test case for an unsteady pipe flow with Michael's
>>>>>> GambitPipe.rea file which sets inlet Recycling BCs based on interpolation
>>>>>> from a cross-section downstream that you specify by a multiple of the
>>>>>> inlet normal:
>>>>>> http://www.mcs.anl.gov/~obabko/z4.tgz
>>>>>> Let me know if you have any questions.
>>>>>> Best,
>>>>>> Aleks
>>>>>> Sent: Thursday, July 8, 2010 5:06:48 PM GMT -06:00 US/Canada Central
>>>>>> Subject: Re: [Nek5000-users] New Recycling BC method?
>>>>>> No worries, just checkin in to see how it was going, thanks for the
>>>>>> update! Look forward to trying it out!
>>>>>> - Michael _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
