[Nek5000-users] New Recycling BC based on interpolation
Fri Jul 16 17:47:28 CDT 2010
Hi Paul,
Thanks for the emails. At present, it seems easier and more straight forward to use a discriminator for RBC so long as it doesn't effect any other routine (like you mentioned other routines that use 'v '). I think, but could be wrong, that the recycling routine negates using the 'v ' boundary condition for that particular inlet?
I think that as long as the discriminator change doesn't effect anything and at the same time, not calling it 'v ' doesn't cause any issues that the discriminator would be easier.
In the mean time I can try creating the bc() based on cbc and geometry location and use that.
- Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Friday, July 16, 2010 5:32:17 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] New Recycling BC based on interpolation
Hi Michael,
As a follow-up --- if you need me to code up a more sophisticated
discriminator, I'm happy to do so.
Paul
On Fri, 16 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Michael,
> Thanks for the suggestion --- I think it's a good one, but we're
> not quite there yet. I have a couple of comments -
> Technically "R " is the same as "v " --- because it is a time-space
> varying prescribed Dirichlet condition.
> Why not simply populate bc(4,f,e,1) with 1,2,3,... to indicate that it is a
> Recycle bc of type 1,2,3,... ? For every cbc, there
> are 6 bc() entries (i.e, bc(k,f,e,1) for k=1 to 6). For "v ", the first one
> of these (k=1) is reserved.
> That being said, genmap doesn't care about any bc other than "O " and
> "P " (in fact, only "P " at this point), so you could in fact do what
> you propose right now, as long as you replace in usrdat or usrdat2 with
> the functionally correct "v " bc.
> At present I'm a bit reluctant to make a change to the repo that is
> still in flux w.r.t. development -- There are a few issues to resolve.
> Presumably what one wants to be able to specify is the translation
> distance -- with respect to what? -- and the scale factor as a function
> of time. We have selected w.r.t. to the unit normal on the R face. In
> exact arithmetic there's no difficulty - but in some tricky situations
> there will be problems. Rather than try to engineer a solution for all
> possible scenarios I think it's best to handle this on a case-by-case
> basis until we get a handle on what works and what doesn't.
> There are also performance issues to be investigated, particularly at
> high processor counts.
> In a few months I expect we'll have a consolidated code team such
> that we can implement changes (at least the mechanics of them)
> without much difficulty. Right now (through the summer) we're
> a bit saturated.
> Paul
>> Oh ok.
>> Let's say that I leave one inlet as 'v ', but then change the other
>> inlet to some other variable 'v1 ' or 'X ' or whatever. Would this be
>> ok, without interfering with other routines?
>> I suppose where this discussion is heading is: What is the possibility
>> of adding a recycling boundary condition explicity in Nek, such that
>> you can apply it like any other boundary condition, say R for example.
>> So, in the routine you now search for this recycling flag 'R', and
>> then run through the setup, rescale etc...?
>> -Michael
>> From: nek5000-users at lists.mcs.anl.gov
>> Sent: Friday, July 16, 2010 4:47:11 PM GMT -06:00 US/Canada Central
>> Hi Michael,
>> Use whatever discrimination you like --- I would not suggest
>> modifying the character bcs, however, save that you can enter
>> values in bc(k,f,e,1) for k > 1, for any cbc(f,e,1) = 'v '
>> The reason for this is that nek checks explicitly for cbc='v '
>> (v, followed by two spaces) in many locations.
>> The correct place for discriminating parameters is in the
>> arracy bc().
>> Normally I discriminate by geometry --- e.g., x < x0, or
>> something similar, occasionally involving the unit normals on
>> the face in question - as that can be a stronger discriminator.
>> Paul
>>> Hi Aleks,
>>> Thank you very much for looking into this. I already have a question; I
>>> noticed that you marked several notes dealing with "RBC single inlet --
>>> modify for other cases". I am assuming this means that you have one inlet
>>> that you want to recycle, but another inlet that you do not want to
>>> recycle, which just happens to be my case.
>>> Can I distinguish in the rea between the two by "v1 " and "v2 " without
>>> giving genmap any problems, and then modify the checks in the usr file
>>> accordingly? Also, the subroutine rescale_inflow mentions to modify for
>>> multiple inlets as well but I do not see where any modification
>>> could/needs to be done for it.
>>> - Michael
>>> Sent: Friday, July 16, 2010 3:03:52 PM GMT -06:00 US/Canada Central
>>> Subject: [Nek5000-users] New Recycling BC based on interpolation
>>> Hi Michael and Markus,
>>> Here is a test case for an unsteady pipe flow with Michael's
>>> GambitPipe.rea file which sets inlet Recycling BCs based on interpolation
>>> from a cross-section downstream that you specify by a multiple of the
>>> inlet normal:
>>> http://www.mcs.anl.gov/~obabko/z4.tgz
>>> Let me know if you have any questions.
>>> Best,
>>> Aleks
>>> Sent: Thursday, July 8, 2010 5:06:48 PM GMT -06:00 US/Canada Central
>>> Subject: Re: [Nek5000-users] New Recycling BC method?
>>> No worries, just checkin in to see how it was going, thanks for the
>>> update! Look forward to trying it out!
>>> - Michael
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100716/e73e2960/attachment.html>
