[Nek5000-users] r,s,t index for given point
Fri Jul 16 14:39:29 CDT 2010
HI Markus -- give me a few minutes and I will send out an email with a
test case that can help you with RBC
Best,
Aleks
On Fri, 16 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Stefan,
> please let me know once you do change the wrapper.
> I think the way I am sailing around not having lglel(iel,nid) is fine since
> it is only done once, at the beginning of the simulation.
> What I was working on is a new way to do the recycling boundary condition
> based on coordinates instead of element counts. This is necessary for us due
> to the usage of Gambit for our more complex geometries. We are still in the
> testing phase, but I think I got it to work.
> What the functions I wrote do is to search for the correct recycling point
> for every grid point on a "v" face (for which I need findpts), then to fill
> the ptr/glo_num variable accordingly (thanks to Paul in the right "memory"
> order - that would have been another third of my hair because intuitively, I
> would have thought its u(1,1,2,1) after u(1,1,1,1), I guess - so thanks).
> Markus
>> Hi Markus,
>> sorry that you had to struggle with all this. You're right the local
>> element number is a 0-based index on the C-side. I think I will change the
>> Fortran C-wrapper back to an index-1 to be compatible with Nek.
>>  Some time ago we changed lglel(iel,nid) to lglel(iel) to reduce the memory
>> footprint.
>> Moreover, we could not think of an application where we really need
>> lglel(iel,nid).
>> What are you trying to do?
>> Stefan
>>  On Jul 14, 2010, at 9:55 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Howdy,
>>> I am not sure if it is of use for anybody else, but the element number as
>>> returned from findpts (vector elid), as for example used in hpts(), can be
>>> converted to a global element number (as it would appear in the rea file)
>>> by:
>>> lglel(elid(i)+1)
>>> I guess the jl/jl2 routines start counting the (local) element index from
>>> 0 instead of 1 - sounds simple here, but I probably pulled out a third of
>>> my scalp hair to figure it out :-)
>>> Also, the variables returned from findpts, even though this function needs
>>> to be called on every node in parallel, are only known to node0, which
>>> makes it necessary to do something like this if one really wants to know
>>> the global number:
>>>  call bcast(proc,lhis*isize)
>>>  call bcast(elid,lhis*isize)
>>>  call bcast(npoints,isize) !Don't do this before jl2 functions are done
>>>  !Zero out globelnum
>>>  do i=1,npoints
>>>    globelnum(i)=0
>>>  enddo
>>>  do i=1,npoints
>>>     if (nid.eq.proc(i)) then
>>>        globelnum(i)=lglel(elid(i)+1)
>>>     endif
>>>  enddo
>>>  call igop(globelnum,w1,'+  ',lhis)
>>> Markus
>>>> Hi Markus,
>>>> lglel reads "local to global element number" so input is
>>>> local element number and output is global element number.
>>>> I'll be seeing Stefan this week so I'm sure we can straighten
>>>> out the interpolation routines.
>>>> You're right about the other points - the ntotv wasn't flagged
>>>> by my compiler and the .his file was taken care of by my own
>>>> scripts, so I didn't catch either of them.  Sorry about that.
>>>> I've updated the source so that those issues should be
>>>> resolved.
>>>> Paul
>>>> On Mon, 12 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi,
>>>>> that was not it, I'm afraid (though I thought gllel transforms from
>>>>> local to global).
>>>>> But I also realized that the hpts routine does not deliver the correct
>>>>> values for me. To test this, I set up a simple 3d box with inflow,
>>>>> outflow and symmetry all around, Re very low, initial condition=boundary
>>>>> condition and 4 points.
>>>>> Please find all files attached, the output for the first point is OK,
>>>>> but then the values seem to shift positions and don't make sense.
>>>>> Also, when running it for 1 step or more, I get the error message:
>>>>> dump history points
>>>>> done :: dump history points
>>>>> hisfile:
>>>>> /Users/m0s1978/nektonruns/rectest/rectest.his
>>>>> ERROR: .sch file already exists.  ierr=  1
>>>>> And lastly, the newest repo won't compile, here is the error message:
>>>>> Error: /Users/m0s1978/nek5trial/trunk/nek/drive2.f, line 1551: This name
>>>>> has already been assigned a data type.   [NVTOT]
>>>>>     integer*8 ntot,nvtot,nptot
>>>>> Thanks for any help,
>>>>> Markus
>>>>>> Hi Markus,
>>>>>> It's possible that it's returning the local (to the processor)
>>>>>> element number.  You would get the global (to the computational
>>>>>> domain, defined by the .rea file) element number via:
>>>>>>       integer e,eg
>>>>>>       eg = lglel(e)
>>>>>> Paul
>>>>>> On Sun, 11 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi again,
>>>>>>> Regarding finding element numbers (such as what gllel would return)
>>>>>>> for arbitrary history points, I was experimenting with the history
>>>>>>> point routine hpts a little and it seems that this function call:
>>>>>>>       call findpts(inth_hpts,rcode,1,
>>>>>>>    &                 proc,1,
>>>>>>>    &                 elid,1,
>>>>>>>    &                 rst,ndim,
>>>>>>>    &                 dist,1,
>>>>>>>    &                 pts(1,1),ndim,
>>>>>>>    &                 pts(2,1),ndim,
>>>>>>>    &                 pts(3,1),ndim,npoints)
>>>>>>> does not return the same element number (elid) as it can be found in
>>>>>>> the .rea file, for instance.
>>>>>>> For a handful of manually set points, I checked that the returned
>>>>>>> element number does not provide the right coordinates to enclose the
>>>>>>> desired point.
>>>>>>> Is there a way to transform the function return or am I missing
>>>>>>> something else?
>>>>>>> Thanks,
>>>>>>> Markus
>>>>>>> _______________________________________________
>>>>>>> Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
