[Nek5000-users] Marangoni flow
Thu Jul 15 18:47:48 CDT 2010
Hi Frank,
Does the chaotic behavior go away when you raise N ?
Paul
On Thu, 15 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
At present we are working on understanding some rotating/traveling waves
that occur in a cylindrical geometry.  In particular, the effect of the
grid on the solution is of interest.  The results from the following
grid in the xy plane, (it is simply extruded in the z direction) exhibit
a somewhat unexpected (chaotic) behavior.  Would welcome any and all
comments concerning the quality of this mesh.
http://www.cct.lsu.edu/~fmuldoo/temp/m-3.png
P.S. The reason for looking at a mesh with m=3 symmetry is due to the
existence of either m=3 and m=4 rotating/traveling waves; meshes with
m=3 and m=5 symmetry have also been looked at and give identical (non
chaotic) results.
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Vienna Technical University)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
