[Nek5000-users] **ERROR**: Failed in HMHOLTZ
Tue Jan 19 08:06:51 CST 2010
Here my usr-file. For some tests I'm using a fixed driving force ffz
and calculate my u_bar in every timestep (subroutine calc_ubar).
The calculation also works if I'm only setting p94 to zero (projection
of the velocity)...
What do you mean by "what happens if you integrate for say 1
flow-through time"??
C-----------------------------------------------------------------------
C  nek5000 user-file template
C
C  user specified routines:
C     - userbc : boundary conditions
C     - useric : initial conditions
C     - uservp : variable properties
C     - userf  : local acceleration term for fluid
C     - userq  : local source term for scalars
C     - userchk: general purpose routine for checking errors etc.
C
      subroutine uservp (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
      udiff  = 0.0
      utrans = 0.0
      return
      end
c-----------------------------------------------------------------------
      subroutine userf  (ix,iy,iz,eg)
c
c     Note: this is an acceleration term, NOT a force!
c     Thus, ffx will subsequently be multiplied by rho(x,t).
c
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
      ffx = 0.0
      ffy = 0.0
      ffz = 0.05
      return
      end
      subroutine userq  (ix,iy,iz,eg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      integer e,f,eg
c     e = gllel(eg)
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      include 'ZPER'  ! for nelx,nely,nelz
      call calc_ubar(vz,1.0)
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux   = 0.0
      uy   = 0.0
      uz   = 0.0
      temp = 0.0
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux   = 0.0
      uy   = 0.0
      uz   = (1-(y-0.5)**2)
      temp = 0.0
      return
      end
      subroutine usrdat   ! This routine to modify element vertices
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine usrdat2  ! This routine to modify mesh coordinates
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine usrdat3
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine calc_ubar(u,idir)  ! driving force for Ubar = 1
      include 'SIZE'
      include 'TOTAL'
      common /uforce/ utldo(ldim)
      n=nx1*ny1*nz1*nelv
      if (istep.eq.0) f_new=param(71)  ! Update forcing for Ubar = 2
      ubar    = glsc2(u,bm1,n)/volvm1
      open(unit=10,file='u_bar.out')
      write(10,*) ubar,ISTEP,TIME
      return
      end
