[Nek5000-users] Number of processors
Wed Feb 3 05:35:54 CST 2010
Fred,
LP is the upper bound on number of processors.
The actual number is determined at run-time by your mpirun or mpiexec
command.  Are you running on with a queuing system? or just on a local
cluster.
For a local cluster, I use the following script (nekbmpi, which runs
the job in background..)
echo $1        >  SESSION.NAME
echo `pwd`'/' >>  SESSION.NAME
touch $1.rea
rm -f logfile
rm -f ioinfo
mv $1.log.$2 $1.log1.$2
mv $1.sch $1.sch1
mpiexec -np $2 nek5000 > $1.log.$2 &
ln $1.log.$2 logfile
Usage:   nekbmpi myjob 8
would run myjob.rea on 8 processors and put the results into myjob.log.8
I have a similar script for a variety of queuing systems... I find they
usually have to be tailored the particular queuing system but it makes
it very easy to use.  I can send you one of these if you'd like.
Paul
On Wed, 3 Feb 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hallo,
> just a short quastion: How can I define the number of processors?? I only
> found in the SIZEu-file the parameter LP, for the maximum number of
> processors..
> Thx a lot.
> Fred
> Nek5000-users mailing list
