[Nek5000-users] Post-Processing from avg_all files using Nek / Visit
Thu Dec 30 12:22:07 CST 2010
Hi Hank,
Thanks. I think I can automate (with python) till I get Visit to do a line
plot. Do you know a way I can just export the data from line plot to a text
file ? I might have about 10 line plots (900 time steps) which I would like
to automate.
Regards
Shriram Jagannathan
On 30 December 2010 12:15, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Shiriam,
> It is pretty easy to automate this in VisIt.  As we discussed at the user's
> meeting, VisIt treats each spectral element as a 5x5x5, 7x7x7, etc group of
> hexahedrons.  Within each hexahedron, there is linear interpolation.
> So: if you want help automating this in VisIt, that should be easy.  As far
> as accuracy, Nek will clearly do the best job, but hopefully you now
> understand better what VisIt is doing...
>  Best,
> Hank
> On Thu, Dec 30, 2010 at 10:12 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi,
>> I would like to post-process quantities from avg_all files (rms, rm2,
>> avg). Particularly I am looking at line plots (mainly) or contours on a
>> plane. I had a question regarding the approach that I might be taking..
>> If I load the files, say rmsblah.f0000* into nek using the load subroutine
>> and fill the ux,uy,uz arrays with that of <u^2>, <v^2>, <w^2> and call
>> hpts(), how would the interpolation work ? Would it interpolate <u^2> with
>> the interpolation that is used for velocities ?. The other option would be
>> to do a line plot from Visit and export it to a text file. Also, I am not
>> sure how Visit interpolates. Which is more likely to be accurate ?
>> Regards
>> Shriram
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101230/709a7c5c/attachment.html>
