[Nek5000-users] 2D axisymmetric problems
Tue Dec 14 12:38:24 CST 2010
Hi Mike,
In the 'axi' example, genbox produces an unnecessary line in the .rea file
when the .re2/.rea files are created.  If you delete the following line from
axi.rea, it should work:
 ***** NO THERMAL BOUNDARY CONDITIONS *****
We are working on the azimuthal velocity issue.
Katie
On Tue, Dec 14, 2010 at 8:53 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello All.
> I have a couple of questions regarding simulation of 2D axisymmetric
> problems where there's a nonzero azimuthal velocity component.
> First, does the new .rea + .re2 format work with such problems?  I tried
> this with the "axi" problem in the examples directory, and things halted
> with
>    ERROR READING INITIAL CONDITION/DRIVE FORCE DATA
>  ABORTING IN ROUTINE RDICDF.
> It worked fine if I stuck with the older .rea format.
> Second, when doing such problems a while back, we would trick nek for such
> problems by using temperature to represent the azimuthal velocity.  This
> approach required one to add appropriate terms into the .usr file.  Is this
> still the case, or is Nek's third velocity component now the azimuthal
> velocity?
> Thanks.
> --Mike
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20101214/99294f11/attachment.html>
