[Nek5000-users] Can Prenek read VTK like mesh ?
Mon Dec 6 09:41:01 CST 2010
Yes - it can read it.  The mesh needs to be in ascii
and there is usually some modification required either
to the source or to the header since the vtk file formats
can be varied.
You can either edit your prenek source or your file to
suit, or if you wish to send me a sample vtk file, I can
update prenek to handle this.
Paul
On Fri, 3 Dec 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello, everyone,
> I'm using Prenek to create a *.rea file.
> At the stage of "BUILD INTERACTIVELY ", there is a menu "IMPORT vtk MESH",
> so I tried to load a vtk mesh generated by GMSH,
> but unfortunately, I got errors like this:
> At line 2119 of file build.f (unit = 48, file = 'my_vtk.tmp')
> Fortran runtime error: Bad integer for item 1 in list input
> Does prenek support vtk format mesh ?
> Zhicheng Wang
