[Nek5000-users] lelx vs nelx
Fri Aug 27 06:04:38 CDT 2010
Thank you
francesco
On 08/27/2010 12:50 PM, nek5000-users at lists.mcs.anl.gov wrote:
> You typically need this only if you are using the fast
> tensor-product solver with the Pn-Pn-2 method.
> You can safely set it to 1, and set params 116-118 to 0
> in the .rea or .usr file.
> Paul
> On Fri, 27 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I am not exactly understanding what is the LELX parameter and how to
>> use it.
>> ( LELX/LELY/LELZ: Maximum number of elements per processor for global
>> fdm solver )
>> and why sometime in the code there is this check
>> (for example in the  turbchannel's userchk or in genbox.f) :
>>          if(nelx.gt.lelx .or. nely.gt.lely .or. nelz.gt.lelz) then
>>           if(nid.eq.0) write(6,*) 'ABORT: nel_xyz > lel_xyz!'
>>           call exitt
>>         endif
>> can anyone help me on that ?
>> thank you a lot
>> francesco
> Nek5000-users mailing list
