[Nek5000-users] Temperature gradient at a point
Thu Aug 26 15:55:54 CDT 2010
Hi Mike,
My solution blows up very quickly. I get NaNs with IFLOMACH turned on along
with the conjugate heat transfer. With IFLOMACH turned off, and only
conjugate heat transfer, I get a solution (it doesn't diverge).
Pradeep
 Initialization successfully completed   0.48088E-01 sec
Starting time loop ...
     DT/DTCFL/DTFS/DTINIT   0.500E-01   0.138E+00   0.000E+00   0.500E-01
Step      1, t= 5.0000000E-02, DT= 5.0000000E-02, C=  0.181 0.0000E+00
0.0000E+00
             Solving for heat
  Temperature/Passive scalar solution
  1.00000000000000002E-008  p22            1           2
 New CG1-tolerance (RINIT*epsm) =   3.99554968277585449E-013
4.18439146179870359E-026
  1     1 Helmholtz TEMP    F:   3.9955E+00   1.0000E-08   5.0000E-01
1.3014E+21
  1     2 Helmholtz TEMP    F:   1.6451E+00   1.0000E-08   5.0000E-01
1.3014E+21
  1     3 Helmholtz TEMP    F:   6.9986E-01   1.0000E-08   5.0000E-01
1.3014E+21
  1     4 Helmholtz TEMP    F:   2.0955E-01   1.0000E-08   5.0000E-01
1.3014E+21
  1     5 Helmholtz TEMP    F:   5.1302E-02   1.0000E-08   5.0000E-01
1.3014E+21
  1     6 Helmholtz TEMP    F:   8.2185E-03   1.0000E-08   5.0000E-01
1.3014E+21
  1     7 Helmholtz TEMP    F:   3.9404E-03   1.0000E-08   5.0000E-01
1.3014E+21
  1     8 Helmholtz TEMP    F:   8.6209E-04   1.0000E-08   5.0000E-01
1.3014E+21
  1     9 Helmholtz TEMP    F:   1.7760E-03   1.0000E-08   5.0000E-01
1.3014E+21
  1    10 Helmholtz TEMP    F:   2.1193E-04   1.0000E-08   5.0000E-01
1.3014E+21
  1    11 Helmholtz TEMP    F:   7.9794E-05   1.0000E-08   5.0000E-01
1.3014E+21
  1    12 Helmholtz TEMP    F:   9.6693E-06   1.0000E-08   5.0000E-01
1.3014E+21
  1    13 Helmholtz TEMP    F:   1.3215E-06   1.0000E-08   5.0000E-01
1.3014E+21
  1    14 Helmholtz TEMP    F:   6.8863E-11   1.0000E-08   5.0000E-01
1.3014E+21
          1    Hmholtz TEMP:     13   6.8863E-11   3.9955E+00   1.0000E-08
          1   5.0000E-02  3.0169E-03 Heat done
             Solving for fluid
  1.00000000000000002E-008  p22            1           1
    1 1.00000E-06         NaN         NaN         NaN       1 Divergence
    2 1.00000E-06         NaN         NaN         NaN       1 Divergence
    3 1.00000E-06         NaN         NaN         NaN       1 Divergence
    4 1.00000E-06         NaN         NaN         NaN       1 Divergence
    5 1.00000E-06         NaN         NaN         NaN       1 Divergence
    6 1.00000E-06         NaN         NaN         NaN       1 Divergence
    7 1.00000E-06         NaN         NaN         NaN       1 Divergence
    8 1.00000E-06         NaN         NaN         NaN       1 Divergence
    9 1.00000E-06         NaN         NaN         NaN       1 Divergence
   10 1.00000E-06         NaN         NaN         NaN       1 Divergence
   11 1.00000E-06         NaN         NaN         NaN       1 Divergence
   12 1.00000E-06         NaN         NaN         NaN       1 Divergence
   13 1.00000E-06         NaN         NaN         NaN       1 Divergence
   14 1.00000E-06         NaN         NaN         NaN       1 Divergence
   15 1.00000E-06         NaN         NaN         NaN       1 Divergence
   16 1.00000E-06         NaN         NaN         NaN       1 Divergence
   17 1.00000E-06         NaN         NaN         NaN       1 Divergence
   18 1.00000E-06         NaN         NaN         NaN       1 Divergence
   19 1.00000E-06         NaN         NaN         NaN       1 Divergence
   20 1.00000E-06         NaN         NaN         NaN       1 Divergence
   21 1.00000E-06         NaN         NaN         NaN       1 Divergence
   22 1.00000E-06         NaN         NaN         NaN       1 Divergence
   23 1.00000E-06         NaN         NaN         NaN       1 Divergence
   24 1.00000E-06         NaN         NaN         NaN       1 Divergence
   25 1.00000E-06         NaN         NaN         NaN       1 Divergence
   26 1.00000E-06         NaN         NaN         NaN       1 Divergence
   27 1.00000E-06         NaN         NaN         NaN       1 Divergence
   28 1.00000E-06         NaN         NaN         NaN       1 Divergence
   29 1.00000E-06         NaN         NaN         NaN       1 Divergence
   30 1.00000E-06         NaN         NaN         NaN       1 Divergence
   31 1.00000E-06         NaN         NaN         NaN       1 Divergence
   32 1.00000E-06         NaN         NaN         NaN       1 Divergence
   33 1.00000E-06         NaN         NaN         NaN       1 Divergence
   34 1.00000E-06         NaN         NaN         NaN       1 Divergence
   35 1.00000E-06         NaN         NaN         NaN       1 Divergence
   36 1.00000E-06         NaN         NaN         NaN       1 Divergence
   37 1.00000E-06         NaN         NaN         NaN       1 Divergence
   38 1.00000E-06         NaN         NaN         NaN       1 Divergence
   39 1.00000E-06         NaN         NaN         NaN       1 Divergence
   40 1.00000E-06         NaN         NaN         NaN       1 Divergence
   41 1.00000E-06         NaN         NaN         NaN       1 Divergence
   42 1.00000E-06         NaN         NaN         NaN       1 Divergence
   43 1.00000E-06         NaN         NaN         NaN       1 Divergence
   44 1.00000E-06         NaN         NaN         NaN       1 Divergence
   45 1.00000E-06         NaN         NaN         NaN       1 Divergence
   46 1.00000E-06         NaN         NaN         NaN       1 Divergence
   47 1.00000E-06         NaN         NaN         NaN       1 Divergence
   48 1.00000E-06         NaN         NaN         NaN       1 Divergence
   49 1.00000E-06         NaN         NaN         NaN       1 Divergence
   50 1.00000E-06         NaN         NaN         NaN       1 Divergence
   51 1.00000E-06         NaN         NaN         NaN       1 Divergence
   52 1.00000E-06         NaN         NaN         NaN       1 Divergence
   53 1.00000E-06         NaN         NaN         NaN       1 Divergence
   54 1.00000E-06         NaN         NaN         NaN       1 Divergence
On Thu, Aug 26, 2010 at 3:30 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> What's the error message you are getting?
> It may be the case, I know that I have had issues with settings and conj HT
> before since they are (mainly because of our group) revisiting CHT and
> fixing issues that we request. The latest issue, like I mentioned, was the
> new time stepping scheme and CHT.
> Did the error show up during compiling, or during the run in the output
> log?
>  - Mike
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Thursday, August 26, 2010 2:18:39 PM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] Temperature gradient at a point
> Hi,
> Is there any reason why a conjucate heat transfer case should not work with
> IFLOMACH turned on?
> I did modify the uservp to set utrans = 1./temp.
> Thanks,
> Pradeep
> c-----------------------------------------------------------------------
>       subroutine uservp (ix,iy,iz,ieg)
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       if (ifield.eq.1) then
>          utrans  = 1./temp
> c         utrans = param(1)
>          udiff   = param(2)
>       else
>          utrans  = 1./temp        ! thermal properties
> c         utrans = param(7)
>          udiff   = param(8)
>          if (ieg .gt. nelgv) then  ! properties in the solid
>             udiff   = 0.1*param(8) ! conductivity
>             utrans  = 1.0
>          endif
>       endif
>       return
>       end
> On Mon, Aug 23, 2010 at 4:40 PM, Pradeep Rao <stringsofdurga at gmail.com>wrote:
>> Thanks Aleks,
>> Will give that a try.
>> On Mon, Aug 23, 2010 at 4:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Pradeep,
>>> Dependence of conductivity on time and space is not a problem once one
>>> uses non zero p30 in .rea that activates a call to uservp of .usr file
>>> If you also need a dependence of conductivity on temperature you may want
>>> to consider either using the values from the previous time step or doing
>>> extrapolation in time.
>>> Best,
>>> Aleks
>>> On Mon, 23 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>  Hi Paul,
>>>> Thanks for the detailed reply. The reason I'm not solving it as a
>>>> conjugate
>>>> heat transfer problem, is that thermal conductivity is a function of
>>>> temperature based on some curve fit equations, and I am not sure how to
>>>> implement that.
>>>> Thanks,
>>>> Pradeep
>>>> On Mon, Aug 23, 2010 at 4:04 PM, <nek5000-users at lists.mcs.anl.gov>
>>>> wrote:
>>>>> Hi Pradeep,
>>>>> Why not just solve the conjugate heat transfer problem directly
>>>>> using fluid + solid elements in nek?
>>>>> Also, nek supports full Robin boundary conditions if you wish
>>>>> to do a Newton law of cooling:  k*dT/dn . n_hat = h*(T-Tinf), where
>>>>> Tinf is
>>>>> the external temperature and h is the heat transfer coefficient, both
>>>>> of
>>>>> which can be functions of time and space.
>>>>> Regarding gradm1, you would call it from userchk, and store
>>>>> the output in arrays in a common block, e.g., as below.
>>>>> Paul
>>>>>     subroutine userchk
>>>>>     common /mygrad/ tx(lx1,ly1,lz1,lelt)
>>>>>    $              , ty(lx1,ly1,lz1,lelt)
>>>>>    $              , tz(lx1,ly1,lz1,lelt)
>>>>>     call gradm1(tx,ty,tz,t)
>>>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,eg
>>>>>     e = gllel(eg) ! global element number to processor-local el. #
>>>>>     gtx=tx(ix,iy,iz,e)
>>>>>     gty=ty(ix,iy,iz,e)
>>>>>     gtz=tz(ix,iy,iz,e)
>>>>>  Hi Paul,
>>>>>> I am basically trying to solve a conjugate heat transfer problem in an
>>>>>> iterative manner, for flow over an infinitely long cylinder (2D).
>>>>>> I need to use the heat transfer at the boundary, to calculate the new
>>>>>> temperature at the boundary for the next time step. The
>>>>>> temperature for the next time step is solved for using this heat flux,
>>>>>> by
>>>>>> a
>>>>>> function in the usr file using an FEM algorithm for the solid part
>>>>>> (cylinder). The bc type I am using is Temperature - fortran function.
>>>>>> Regards,
>>>>>> Pradeep
>>>>>> On Mon, Aug 23, 2010 at 2:50 PM, <nek5000-users at lists.mcs.anl.gov>
>>>>>> wrote:
>>>>>>  Pradeep,
>>>>>>> if you give me some idea of the nature of your bc, I can
>>>>>>> perhaps help --- there are a large number of bc types already
>>>>>>> supported inside nek
>>>>>>> Paul
>>>>>>>  Hi,
>>>>>>>> I wanted to know if there was a way to find the temperature gradient
>>>>>>>> at
>>>>>>>> a
>>>>>>>> point. I need that information in the userbc function.
>>>>>>>> I tried using gradm1(), but I am not sure how to get the value at a
>>>>>>>> given
>>>>>>>> point.
>>>>>>>> Thanks,
>>>>>>>> Pradeep
>>>>>>>>  _______________________________________________
>>>>>>>>  Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>> Pradeep C. Rao
>>>>>> Graduate Research Assistant for FT2L (
>>>>>> http://www1.mengr.tamu.edu/FT2L/)
>>>>>> Department of Mechanical Engineering
>>>>>> Texas A&M University
>>>>>> College Station, TX 77843-3123
>>>>>> 428 Engineering Physics Building
>>>>>> (713) 210-9769
>>>>>>  uuuu
>>>>> C
>>>>> C  USER SPECIFIED ROUTINES:
>>>>> C
>>>>> C     - boundary conditions
>>>>> C     - initial conditions
>>>>> C     - variable properties
>>>>> C     - local acceleration for fluid (a)
>>>>> C     - forcing function for passive scalar (q)
>>>>> C     - general purpose routine for checking errors etc.
>>>>> C
>>>>>     subroutine uservp (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>>     udiff =0.
>>>>>     utrans=0.
>>>>>     return
>>>>>     end
>>>>>     subroutine userf  (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>> c     Note: this is an acceleration term, NOT a force!
>>>>> c     Thus, ffx will subsequently be multiplied by rho(x,t).
>>>>>     ffx = 0.0
>>>>>     ffy = 0.0
>>>>>     ffz = 0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine userq  (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>>     qvol   = 0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine userchk
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     return
>>>>>     end
>>>>>     subroutine userbc (ix,iy,iz,iside,ieg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     ux=0.0
>>>>>     uy=0.0
>>>>>     uz=0.0
>>>>>     temp=0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine useric (ix,iy,iz,ieg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     ux=0.0
>>>>>     uy=0.0
>>>>>     uz=0.0
>>>>>     temp=0
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>> c
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat2
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     param(66) = 4.   ! These give the std nek binary i/o and are
>>>>>     param(67) = 4.   ! good default values
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat3
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>> c
>>>>>     return
>>>>>     end
>>>> Pradeep C. Rao
>>>> Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/)
>>>> (713) 210-9769
>> Pradeep C. Rao
>> (713) 210-9769
> Pradeep C. Rao
> (713) 210-9769
> _______________________________________________ Nek5000-users mailing list
Pradeep C. Rao
(713) 210-9769
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100826/f1e06826/attachment.html>
