[Nek5000-users] postpro.f compiler problems
Mon Aug 23 16:13:42 CDT 2010
Ok, it worked!  Thank you, Stefan!
nek5000-users at lists.mcs.anl.gov wrote:
> No, I didn't.  I'll uncomment it and try again.  Thank you!
> Elizabeth
>> Your compiler problem seems to be related to the fact that the lpart
>> parameter is commented. Did you comment this parameter?
>> c automatically added by makenek
>> c      parameter(lpart = 10000  ) ! max number of particles
>> Stefan
>> On Mon, Aug 23, 2010 at 10:21 PM, <nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>     Here is the SIZE file.
>>     Elizabeth
>>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>         Hi,
>>         please post your SIZE file.
>>         Stefan
>>         On Mon, Aug 23, 2010 at 8:17 PM,
>>         <mailto:nek5000-users at lists.mcs.anl.gov>>> wrote:
>>            Hi,
>>            I tried to update to the newest version of the code, but I
>>         am having
>>            trouble getting it to compile. It is having a problem with
>>         compiling
>>            postpro.f.  It looks like the compiler fails at line 1364
>> when
>>            parameter
>>            is used to set a variable equal to a non-constant quantity
>>         instead
>>            of a
>>            constant one.  It looks like this was added in version 537 by
>>            Stefan. I've included the end of the output from the
>> compiler,
>>            which is the Portland group compiler on Franklin.   At Aleks'
>>            suggestion I tried deleting the subroutine g2gi, but that
>>         did not
>>            fix the problem. I was finally able to get it to compile by
>>         using
>>            postpro.f from version 536 and deleting the subroutine
>>         hpts.      That subroutine was causing a similar problem.
>>         Elizabeth
>>            PGF90-S-0050-Assumed size array, rst, is not a dummy argument
>>            (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 448)
>>            PGF90-S-0050-Assumed size array, dist, is not a dummy
>> argument
>>            PGF90-S-0050-Assumed size array, rcode, is not a dummy
>> argument
>>            (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 449)
>>            PGF90-S-0050-Assumed size array, elid, is not a dummy
>> argument
>>            PGF90-S-0050-Assumed size array, proc, is not a dummy
>> argument
>>            0 inform,   0 warnings,   5 severes, 0 fatal for intpts
>>            /opt/cray/xt-asyncpe/3.7/bin/ftn: INFO: linux target is
>>         being used
>>            ftn -c  -O2 -r8 -Mpreprocess -DMPI -DLONGINT8 -DUNDERSCORE
>>            -DGLOBAL_LONG_LONG
>>         -I/scratch/scratchdirs/ehicks/nek/runs/run325
>>            -I/global/homes/e/ehicks/nek5_svn/trunk/nek -I./
>>            /global/homes/e/ehicks/nek5_svn/trunk/nek/qthermal.f -o
>>         obj/qthermal.o
>>            PGF90-S-0087-Non-constant expression where constant
>> expression
>>            required (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f
>>            : 1346)
>>            0 inform,   0 warnings,   1 severes, 0 fatal for g2gi
>>            make: *** [obj/postpro.o] Error 2
>>            _______________________________________________
>>            Nek5000-users mailing list
>>            Nek5000-users at lists.mcs.anl.gov
>>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>         <mailto:Nek5000-users at lists.mcs.anl.gov>>
>>            https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>     C     Dimension file to be included
>>     C
>>     C     HCUBE array dimensions
>>     C
>>          parameter (ldim=2)
>>          parameter (lx1=16,ly1=lx1,lz1=1,lelt=36,lelv=lelt)
>>          parameter (lxd=24,lyd=lxd,lzd=1)
>>          parameter (lelx=1,lely=1,lelz=1)
>>     c
>>          parameter (lzl=3 + 2*(ldim-3))
>>     c
>>          parameter (lx2=lx1-2)
>>          parameter (ly2=ly1-2)
>>          parameter (lz2=1)
>>          parameter (lx3=lx2)
>>          parameter (ly3=ly2)
>>          parameter (lz3=lz2)
>>     c
>>     c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
>>     c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
>>     c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
>>     c
>>          parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
>>          parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
>>          parameter (lpx2=1,lpy2=1,lpz2=1)
>>     c
>>     c
>>     c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
>>     c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
>>     c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
>>     c
>>          parameter (lbelv=1,lbelt=1)                ! MHD
>>          parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
>>          parameter (lbx2=1,lby2=1,lbz2=1)
>>     c
>>     C LX1M=LX1 when there are moving meshes; =1 otherwise
>>          parameter (lx1m=1,ly1m=1,lz1m=1)
>>          parameter (ldimt= 1)                       ! 3 passive
>>     scalars + T
>>          parameter (ldimt1=ldimt+1)
>>          parameter (ldimt3=ldimt+3)
>>          parameter (lp   = 1024)
>>          parameter (lelg = 1152)
>>     c
>>     c     Note:  In the new code, LELGEC should be about sqrt(LELG)
>>     c
>>          PARAMETER (LELGEC = 1)
>>          PARAMETER (LXYZ2  = 1)
>>          PARAMETER (LXZ21  = 1)
>>     c
>>          PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
>>          PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
>>          PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
>>          PARAMETER (LXZ=LX1*LZ1)
>>          PARAMETER (LORDER=3)
>>          PARAMETER (MAXOBJ=1,MAXMBR=LELT*6,lhis=10)
>>     C
>>     C     Common Block Dimensions
>>     C
>>          PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
>>          PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
>>     C
>>     C     The parameter LVEC controls whether an additional 42 field
>>     arrays
>>     C     are required for Steady State Solutions.  If you are not using
>>     C     Steady State, it is recommended that LVEC=1.
>>     C
>>          PARAMETER (LVEC=1)
>>     C
>>     C     Uzawa projection array dimensions
>>     C
>>          parameter (mxprev = 20)
>>          parameter (lgmres = 30)
>>     C
>>     C     Split projection array dimensions
>>     C
>>          parameter(lmvec = 1)
>>          parameter(lsvec = 1)
>>          parameter(lstore=lmvec*lsvec)
>>     c
>>     c     NONCONFORMING STUFF
>>     c
>>          parameter (maxmor = lelt)
>>     C
>>     C     Array dimensions
>>     C
>>          COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
>>         $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
>>         $,NXD,NYD,NZD
>>          parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
>>          integer ax1,ay1,az1,ax2,ay2,az2
>>          parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) !
>>     running averages
