[Nek5000-users] Temperature gradient at a point
Mon Aug 23 15:03:11 CDT 2010
Hi Paul,
I am basically trying to solve a conjugate heat transfer problem in an
iterative manner, for flow over an infinitely long cylinder (2D).
I need to use the heat transfer at the boundary, to calculate the new
temperature at the boundary for the next time step. The
temperature for the next time step is solved for using this heat flux, by a
function in the usr file using an FEM algorithm for the solid part
(cylinder). The bc type I am using is Temperature - fortran function.
Pradeep
On Mon, Aug 23, 2010 at 2:50 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Pradeep,
> if you give me some idea of the nature of your bc, I can
> perhaps help --- there are a large number of bc types already
> supported inside nek
> Paul
> On Mon, 23 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi,
>> I wanted to know if there was a way to find the temperature gradient at a
>> point. I need that information in the userbc function.
>> I tried using gradm1(), but I am not sure how to get the value at a given
>> point.
>> Thanks,
>> Pradeep
>>  _______________________________________________
> Nek5000-users mailing list
Pradeep C. Rao
Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/)
Department of Mechanical Engineering
Texas A&M University
College Station, TX 77843-3123
428 Engineering Physics Building
(713) 210-9769
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100823/751e771e/attachment.html>
