[Nek5000-users] Reading binary data
Fri Aug 13 13:27:40 CDT 2010
Stefan,
I'm still having some problems reading the field data properly.   So, please consider a field file that has BOTH mesh data and field data, and assume there are three fields stored (u,v,w,p).
After the initial file data (header: 132 bytes, endian 4 bytes, mapping: nel* 4 bytes), does the mesh data come in single chunk before field data (as discussed in your message below):
LOOP over all elements
	LOOP i = {x,y,z}
		 i for all GLL points (internal element points)
	ENDLOOP
ENDLOOP
If that is indeed all before the field data, is the field data then organized as
  LOOP i = three fields
  ENDLOOP
ENDLOOP
or, is it
  LOOP i = GLL points
	 i for all fields
  ENDLOOP
ENDLOOP
Is there by chance a detailed description for the format of the field file somewhere that I am missing?
--Mike
On Aug 11, 2010, at 3:50 PM, <nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mike,
> vector fields (e.g. mesh coordinates) are stored in the following way:
> 	LOOP i = {x,y,z}
> 	ENDLOOP
> ENDLOOP
> 2D example with (E=2,N=2):
> x1_1 x2_1 x3_1 y1_1 y2_1 y3_1 x1_1 x2_2 x3_2 y1_2 y2_2 y3_2
> where x2_1 means the x-coordinate of the 2nd GLL point of element 1.
> hth,
> Stefan
> On Aug 11, 2010, at 11:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hello All.  I found this helpful message from Stefan regarding the structure of a binary field file.   Could someone please tell me what the structure is when the geometry info is also contained?
>> Thanks!
>> --Mike
>>> Thu May 6 07:18:03 CDT 2010
>>> 	• Previous message: [Nek5000-users] Reading binary data
>>> 	• Next message: [Nek5000-users] History points
>>> 	• Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
>>> Hi Fred,
>>> header: 132 bytes
>>> endian test tag: 4 bytes
>>> element mapping: nel* 4 bytes
>>> data: nfields*nxyz*nel* wdsizo (where wdsizo is 4 or 8 bytes)
>>> metadata (min/max values): nfields*2*nel * 4 bytes
>>> Stefan
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
