[Nek5000-users] Reading binary data
Thu Aug 12 02:06:45 CDT 2010
The 12288 bytes is the metadata for all 3 mesh coordinates:
ndim * nel * 2 * 4 bytes
Stefan
On Aug 12, 2010, at 12:21 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Sorry -- I'm still not getting it.
> The first file had mesh coordinates and field information in it; here is what the header shows:
> #std 4  8  8  8        512        512  0.2000000000000E+02      1000      0      1 XUPS02
> The size of this file is  9476232, but I can't figure out what is contributing to that size.  For the next field file, the header shows:
> #std 4  8  8  8        512        512  0.1200000000000E+03      6000      0      1 UPS02
> The size of this file is 6318216, which is exactly predicted by the expression below -- all is well.
> What is the makeup of the 3158016 bytes difference between these files?  The mesh coordinates alone are only
> 512 * 8^3 * 4 * 3 (ndim) = 3145728 bytes
> Where and what are the remaining 12288 bytes?
> Thanks.
> On Aug 11, 2010, at 4:09 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> No, if a field file only contains the geometry (mesh coordinates) nfields is equal to ndim (2 or 3).
>> Stefan
>> On Aug 12, 2010, at 12:01 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Stefan,
>>> Thanks.  I figured that, but the binary file size doesn't seem to be adding up.    For example,  a field file that doesn't have geometry data is the size described by the initial thread, i.e.
>>> 132 bytes + 4 bytes + nel* 4 bytes + nfields*nxyz*nel* wdsizo  +  nfields*2*nel * 4 bytes
>>> My naive assumption was that a field file with xyz data would then have the additional space requirement of
>>> nx*ny*nz*nel*wdsizo
>>> but the file's bigger than that.  What info am I missing?
>>> --Mike
>>> On Aug 11, 2010, at 3:50 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Hi Mike,
>>>> vector fields (e.g. mesh coordinates) are stored in the following way:
>>>> LOOP over all elements
>>>> 	LOOP i = {x,y,z}
>>>> 		 i for all GLL points (internal element points)
>>>> 	ENDLOOP
>>>> ENDLOOP
>>>> 2D example with (E=2,N=2):
>>>> x1_1 x2_1 x3_1 y1_1 y2_1 y3_1 x1_1 x2_2 x3_2 y1_2 y2_2 y3_2
>>>> where x2_1 means the x-coordinate of the 2nd GLL point of element 1.
>>>> hth,
>>>> Stefan
>>>> On Aug 11, 2010, at 11:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> Hello All.  I found this helpful message from Stefan regarding the structure of a binary field file.   Could someone please tell me what the structure is when the geometry info is also contained?
>>>>> Thanks!
>>>>> --Mike
>>>>>> Thu May 6 07:18:03 CDT 2010
>>>>>> 	• Previous message: [Nek5000-users] Reading binary data
>>>>>> 	• Next message: [Nek5000-users] History points
>>>>>> 	• Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
>>>>>> Hi Fred,
>>>>>> header: 132 bytes
>>>>>> endian test tag: 4 bytes
>>>>>> element mapping: nel* 4 bytes
>>>>>> data: nfields*nxyz*nel* wdsizo (where wdsizo is 4 or 8 bytes)
>>>>>> metadata (min/max values): nfields*2*nel * 4 bytes
>>>>>> Stefan
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
