[Nek5000-users] Reading binary data
Wed Aug 11 17:09:43 CDT 2010
No, if a field file only contains the geometry (mesh coordinates) nfields is equal to ndim (2 or 3).
Stefan
On Aug 12, 2010, at 12:01 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Stefan,
> Thanks.  I figured that, but the binary file size doesn't seem to be adding up.    For example,  a field file that doesn't have geometry data is the size described by the initial thread, i.e.
> 132 bytes + 4 bytes + nel* 4 bytes + nfields*nxyz*nel* wdsizo  +  nfields*2*nel * 4 bytes
> My naive assumption was that a field file with xyz data would then have the additional space requirement of
> nx*ny*nz*nel*wdsizo
> but the file's bigger than that.  What info am I missing?
> --Mike
> On Aug 11, 2010, at 3:50 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Mike,
>> vector fields (e.g. mesh coordinates) are stored in the following way:
>> LOOP over all elements
>> 	LOOP i = {x,y,z}
>> 		 i for all GLL points (internal element points)
>> 	ENDLOOP
>> ENDLOOP
>> 2D example with (E=2,N=2):
>> x1_1 x2_1 x3_1 y1_1 y2_1 y3_1 x1_1 x2_2 x3_2 y1_2 y2_2 y3_2
>> where x2_1 means the x-coordinate of the 2nd GLL point of element 1.
>> hth,
>> Stefan
>> On Aug 11, 2010, at 11:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hello All.  I found this helpful message from Stefan regarding the structure of a binary field file.   Could someone please tell me what the structure is when the geometry info is also contained?
>>> Thanks!
>>> --Mike
>>>> Thu May 6 07:18:03 CDT 2010
>>>> 	• Previous message: [Nek5000-users] Reading binary data
>>>> 	• Next message: [Nek5000-users] History points
>>>> 	• Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
>>>> Hi Fred,
>>>> header: 132 bytes
>>>> endian test tag: 4 bytes
>>>> element mapping: nel* 4 bytes
>>>> data: nfields*nxyz*nel* wdsizo (where wdsizo is 4 or 8 bytes)
>>>> metadata (min/max values): nfields*2*nel * 4 bytes
>>>> Stefan
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
