[Nek5000-users] Performance problem
Fri Aug 6 08:08:57 CDT 2010
Mani,
I think there must be something else wrong ... I'm seeing about
5 sec/step on a 64 proc. linux cluster.
If you'd like to send me a gzip'd file w/ the essentials, contact
me off-list (fischer at mcs.anl.gov) and I can take a closer look.
Paul
On Fri, 6 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
> If you set p94 & p95 to 5 (say), I recommend strongly to set p12 (dt) to
>   -3e-5
> in your case.   The reason for this is that the projection scheme is much
> more stable for fixed dt.
> On the whole, however, Stefan's earlier comments about using, say, lx1=8
> and fewer elements is a better strategy.   It's also possible that we should
> switch your coarse-grid solve at this scale to AMG.
> Paul
>>> - set param(102) and param(103) to 5 (this will turn on the residual
>>> projection)
>>    Should this be param 94 & 95 ?
>>    - Paul
>>> Ok here are some suggestions to improve the performance:
>>> - set timestep, param(12), to -3e-5
>>> projection)
>>> - increase lgmres (in SIZE) to 40
>>> - you have want to tune the Helmholtz (velocity) and pressure tolerance
>>> (e.g. 1e-8 and 1e-5)
>>> btw: what's the Reynolds number of this flow?
>>> Stefan
>>> On Aug 6, 2010, at 11:13 AM, <nek5000-users at lists.mcs.anl.gov>
>>> <nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Dear Mani,
>>>> I haven't checked your logfile yet but there are my first thoughts:
>>>> N=4 is low
>>>> Your polynomial order (N=4) is low and the tensor-product formulation
>>>> won't buy you much. The performance of all matrix-matrix multiplies (MxM)
>>>> will limited by the memory access times. This is in particular a problem
>>>> on multi-core and multi-socket machines. We have seen that the
>>>> performance drop can be significant.
>>>> On top of that you carry around a large number of duplicate DOF and your
>>>> surface to volume ratio is high (more communication). I
>>>> Parallel Performance
>>>> Your gridpoints per core (~4700) is quite small!
>>>> On Blue Gene (BG) systems we can scale well (e.g. 70-80% parallel
>>>> efficiency) with around 10k gridpoints per core. On other system (e.g.
>>>> Cray XT5) you need much more gridpoints per core (say 80k) because the
>>>> network has a higher latency (NEK is sensitive to latency not bandwidth)
>>>> and the processors are much faster.
>>>> Cheers,
>>>> Stefan
>>>> On Aug 6, 2010, at 10:51 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>> Hi,
>>>>>   I'm solving for Rayleigh-Benard convection in a 3D box of 37632, 4rth
>>>>> order elements. I fired the job on 512 processors on a machine with
>>>>> quad-core, quad socket configuration (32 nodes with 16 cores each ) with
>>>>> a 20 Gbps infiniband interconnect. In 12 hours it has run 163 time
>>>>> steps. Is this normal or is there maybe some way to improve performance?
>>>>> Attached is the SIZE file.
>>>>> Regards,
>>>>> Mani chandra
>>>>> <SIZE.txt>_______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
