[Nek5000-users] Performance problem
Fri Aug 6 05:00:36 CDT 2010
Yes!
On Aug 6, 2010, at 11:55 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> - set param(102) and param(103) to 5 (this will turn on the residual projection)
>    Should this be param 94 & 95 ?
>    - Paul
> On Fri, 6 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Ok here are some suggestions to improve the performance:
>> - set timestep, param(12), to -3e-5
>> - increase lgmres (in SIZE) to 40
>> - you have want to tune the Helmholtz (velocity) and pressure tolerance (e.g. 1e-8 and 1e-5)
>> btw: what's the Reynolds number of this flow?
>> Stefan
>> On Aug 6, 2010, at 11:13 AM, <nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Dear Mani,
>>> I haven't checked your logfile yet but there are my first thoughts:
>>> N=4 is low
>>> Your polynomial order (N=4) is low and the tensor-product formulation won't buy you much. The performance of all matrix-matrix multiplies (MxM) will limited by the memory access times. This is in particular a problem on multi-core and multi-socket machines. We have seen that the performance drop can be significant.
>>> On top of that you carry around a large number of duplicate DOF and your surface to volume ratio is high (more communication). I
>>> Parallel Performance
>>> Your gridpoints per core (~4700) is quite small!
>>> On Blue Gene (BG) systems we can scale well (e.g. 70-80% parallel efficiency) with around 10k gridpoints per core. On other system (e.g. Cray XT5) you need much more gridpoints per core (say 80k) because the network has a higher latency (NEK is sensitive to latency not bandwidth) and the processors are much faster.
>>> Cheers,
>>> Stefan
>>> On Aug 6, 2010, at 10:51 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>> Hi,
>>>>  I'm solving for Rayleigh-Benard convection in a 3D box of 37632, 4rth order elements. I fired the job on 512 processors on a machine with quad-core, quad socket configuration (32 nodes with 16 cores each ) with a 20 Gbps infiniband interconnect. In 12 hours it has run 163 time steps. Is this normal or is there maybe some way to improve performance? Attached is the SIZE file.
>>>> Regards,
>>>> Mani chandra
>>>> <SIZE.txt>_______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
