[Nek5000-users] Restarting simulation from instantenous & average velocity field files
Fri Apr 30 07:37:59 CDT 2010
Hi Harish,
   2 PRESOLVE/RESTART OPTIONS  *****
blah.fld01 X
blah.fld02 U P
will take geometry (say) from .fld01 and velocity/pressure
from fld02, as well as time from the last file listed.
In your case, why not just restart, and then subsequently
average your avg files ?   We have some small codes for
doing this.
Paul
On Fri, 30 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Paul & Stefan,
> I am running a DNS simulation of backward facing simulation (BFS) at
> Re=3000. The Reynolds # is based on step height (h=1) & free stream
> velocity (ux = 1.0). The BFS geometry has 5184 elements and lx1=ly1=lz1=8.
> After running for about 10 flow throughs, we started computing averages. I
> want to restart simulation after 2 flow throughs, but I have 2 field files
> one for instantaneous (blah.fld01) and the other for average
> (avgblah.fld01). To continue computing averages I need to read in both the
> velocity field files. Is there an option to restart from 2 field files? Or
> how else can I do this? I will also require this option later for
> computing "rms" velocities.
> Thanks,
> Harish.
> Nek5000-users mailing list
