[Nek5000-users] Tolerances
Wed Apr 28 08:56:38 CDT 2010
Just to give you some idea of the potential for looking at
these stabilities, resolution reqmts, etc., you might look at:
www.mcs.anl.gov/~fischer/users.pdf
which scopes out several problems, including some stability ones.
(Though I've yet to get the OS problem typed up and put in this
ever-growing document...)
Paul
On Wed, 28 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Stefan,
> Thank you for your quick reply!
> Yes, we have already tried to refine the computational domain by rising the
> polynomial order from 7 to 9 (lx1=8 -> 10) which does not improve the quality
> of the results much (numerical artefacts in the freestream are damped while
> the numerically excited crossflow waves remain unchanged).
> In the case of higher resolution one disturbance wavelength would be resolved
> by 37 points on average which sounds enough to us. We will try to further
> refine the domain and to "play" with the filtering at highest order. Maybe we
> can suppress the numerical noise triggering the physical instability in this
> way...
> Cheers,
> David
> Lars-Uve
>> Do you really think 15 pressure iterations are too much? Considering you
>> strict tolerance I would say it's pretty good! I am not sure what triggers
>> your noise but did you try to use a high resolution?
>> In your case TOLREL/TOLABS are not important!
>> The tolerance you specify in DIVERGENCE is for the pressure solver. In fact
>> if you use the PN/PN_2 scheme you'll end up with a divergence of the
>> velocity which is comparable to DIVERGENCE. The pressure solve projects the
>> velocity on a divergence free space. and you can control the divergence by
>> varying the pressure tolerance (that's why we call it DIVERGENCE). In the
>> PN/PN scheme things are different.
>> The HELMHOLTZ controls the tolerance for all Helmholtz solves so if you
>> don't have any passive scalars it's just for the velocity.
>> Stefan
> Nek5000-users mailing list
