[Nek5000-users] Residuals for post-processing
Sun Apr 25 10:05:09 CDT 2010
this is what I added to usrchk:
       include 'GMRES'
       if (istep.gt.0) then
        call outpost(vx,vy,vz,res,t,'res')
        call exitti('quit in gmres$',n)
       endif
Unfortunately, this causes the code to crash whenever outpost is called:
   120 1.00000E-06 8.11690E-04 5.58247E-01 1.45400E-03       1 Divergence
           1    U-Pres gmres:      120   8.1169E-04   1.0000E-06
5.5825E-01   2.8286E+00   8.0148E+00
            1  DNORM, DIVEX  0.35002708528548815
8.11690205515358640E-004
           1   5.0000E-03  8.3137E+00 Fluid done
filt amp 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0125 0.0500
filt trn 1.0000 1.0000 1.0000 1.0000 1.0000 1.0000 0.9875 0.9500
./nek: line 7: 11765 Segmentation fault      (core dumped) ./nek5000
real    0m27.297s
user    0m9.348s
sys     0m1.124s
I tried with pr instead of res, that works. Is it possible that res is
not an array but a single number?
Where are the residuals for velocity and passive scalars stored?
I added the divergence procedure to the outflow, there is no back flow.
The problem is not that the simulation blows up (at least for the time
steps I am doing), it is that the pressure residuals don't fall below
the specified limit when I increase lx1. This is for both PN/PN-2 and
PN/PN and not a function of dt.
Markus
nek5000-users at lists.mcs.anl.gov wrote:
> Hi Markus,
> pressure residuals are in gmres
> You could output them via:
>     call outpost(x,y,z,res,t,'res')
> where x,y,z,t are arrays of your choice and res
> is the array you want to look at.
> Nek will convert the res mesh to the velocity mesh
> if needed.  I usually follow such a call with
> because prepost() uses some scratch common blocks
> that are potentially shared with the calling routine
> (not in the case of gmres, I think...) -- so data might be corrupted
> after such a call.   The idea of
> prepost was to be called in between timesteps, when
> such memory re-use would be admissable.   The alternative
> would be to define your own storage in a common block,
> save the residuals to this locale, then loop through
> calls to outpost in userchk afterwards...  I've done
> that in the past.
> All this being said, I'm not 100% certain that the
> iterative solvers is the place to look for the difficulty.
> Most problems arise from spatial resolution issues...or
> temporal stability problems.  The latter can be identified
> by drastic reduction in dt.
> What exactly is blowing up for you?
> Paul
> On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I'd like to save the residuals for the pressure iterations (PN/PN-2 as
>> well as PN/PN) into a scalar variable (scalar 0, instead of
>> temperature say) for each grid point in order to see where my solution
>> diverges.
>> Is there a way to add something to the .usr file to do that? I
>> couldn't find the variable in the code and also wouldn't know how to
>> save something from the lx2=lx1-2 grid onto the lx1 grid.
>> Would this also be possible with the velocity residuals?
>> Thanks,
>> Markus
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> uuuu
> c-----------------------------------------------------------------------
>       subroutine uzawa_gmres(res,h1,h2,h2inv,intype,iter)
> c     Solve the pressure equation by right-preconditioned c     GMRES
> iteration.
> c     intype =  0  (steady)
> c     intype =  1  (explicit)
> c     intype = -1  (implicit)
>       include 'SIZE'
>       include 'TOTAL'
>       include 'GMRES'
>       common  /ctolpr/ divex
>       common  /cprint/ ifprint
>       logical          ifprint
>       real             res  (lx2*ly2*lz2*lelv)
>       real             h1   (lx1,ly1,lz1,lelv)
>       real             h2   (lx1,ly1,lz1,lelv)
>       real             h2inv(lx1,ly1,lz1,lelv)
>       common /scrmg/    wp (lx2,ly2,lz2,lelv)
>       common /ctmp0/   wk1(lgmres),wk2(lgmres)
>       common /cgmres1/ y(lgmres)
>       real alpha, l, temp
>       integer j,m
> c
>       logical iflag
>       save    iflag
>       data    iflag /.false./
>       real    norm_fac
>       save    norm_fac
> c
>       real*8 etime1,dnekclock
> c
>       if(.not.iflag) then
>          iflag=.true.
>          call uzawa_gmres_split0(ml,mu,bm2,bm2inv,nx2*ny2*nz2*nelv)
>          norm_fac = 1./sqrt(volvm2)
>       endif
> c
>       etime1 = dnekclock()
>       etime_p = 0.
>       divex = 0.
>       iter  = 0
>       m = lgmres
> c
>       call chktcg2(tolps,res,iconv)
>       if (param(21).gt.0.and.tolps.gt.abs(param(21)))
>      $   tolps = abs(param(21))
> c     if (param(21).lt.0) tolps = abs(param(21))
>       if (istep.eq.0) tolps = 1.e-4
>       tolpss = tolps
> c
>       ntot2  = nx2*ny2*nz2*nelv
> c
>       iconv = 0
>       call rzero(x,ntot2)
>       do while(iconv.eq.0.and.iter.lt.100)
>          if(iter.eq.0) then
>                                                   !      -1
>             call col3(r,ml,res,ntot2)             ! r = L  res
> c           call copy(r,res,ntot2)
>          else
>             !update residual
>             call copy(r,res,ntot2)                ! r = res
>             call cdabdtp(w,x,h1,h2,h2inv,intype)  ! w = A x
>             call add2s2(r,w,-1.,ntot2)            ! r = r - w
>                                                   !      -1
>             call col2(r,ml,ntot2)                 ! r = L   r
>          endif
>                                                   !            ______
>          gamma(1) = sqrt(glsc2(r,r,ntot2))        ! gamma  = \/ (r,r)
>                                                   !      1
>          if(iter.eq.0) then
>             div0 = gamma(1)*norm_fac
>             if (param(21).lt.0) tolpss=abs(param(21))*div0
>          endif
>          !check for lucky convergence
>          rnorm = 0.
>          if(gamma(1) .eq. 0.) goto 9000
>          temp = 1./gamma(1)
>          call cmult2(v(1,1),r,temp,ntot2)         ! v  = r / gamma
>                                                   !  1            1
>          do j=1,m
>             iter = iter+1
>                                                   !       -1
>             call col3(w,mu,v(1,j),ntot2)          ! w  = U   v
>                                                   !           j
>             etime2 = dnekclock()
>             if(param(43).eq.1) then
>                call uzprec(z(1,j),w,h1,h2,intype,wp)
>             else                                  !       -1
>                call hsmg_solve(z(1,j),w)          ! z  = M   w
>             endif
>             etime_p = etime_p + dnekclock()-etime2
>             call cdabdtp(w,z(1,j),                ! w = A z
>      $                   h1,h2,h2inv,intype)      !        j
>                                                   !      -1
>             call col2(w,ml,ntot2)                 ! w = L   w
> c           !modified Gram-Schmidt
> c           do i=1,j
> c              h(i,j)=glsc2(w,v(1,i),ntot2)       ! h    = (w,v )
> c                                                 !  i,j       i
> c              call add2s2(w,v(1,i),-h(i,j),ntot2)! w = w - h    v
> c           enddo                                 !          i,j  i
> c           2-PASS GS, 1st pass:
>             do i=1,j
>                h(i,j)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
>             enddo                                 !  i,j       i
>             call gop(h(1,j),wk1,'+  ',j)          ! sum over P procs
>             do i=1,j
>             enddo                                 !          i,j  i
> c           2-PASS GS, 2nd pass:
> c
> c           do i=1,j
> c              wk1(i)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
> c           enddo                                 !  i,j       i
> c                                                 !
> c           call gop(wk1,wk2,'+  ',j)             ! sum over P procs
> c
> c           do i=1,j
> c              call add2s2(w,v(1,i),-wk1(i),ntot2)! w = w - h    v
> c              h(i,j) = h(i,j) + wk1(i)           !          i,j  i
> c           enddo
>             !apply Givens rotations to new column
>             do i=1,j-1
>                temp = h(i,j)
>                h(i  ,j)=  c(i)*temp + s(i)*h(i+1,j)
>                h(i+1,j)= -s(i)*temp + c(i)*h(i+1,j)
>             enddo
>                                                   !            ______
>             alpha = sqrt(glsc2(w,w,ntot2))        ! alpha =  \/ (w,w)
>             rnorm = 0.
>             if(alpha.eq.0.) goto 900  !converged
>             l = sqrt(h(j,j)*h(j,j)+alpha*alpha)
>             temp = 1./l
>             c(j) = h(j,j) * temp
>             s(j) = alpha  * temp
>             h(j,j) = l
>             gamma(j+1) = -s(j) * gamma(j)
>             gamma(j)   =  c(j) * gamma(j)
> c            call outmat(h,m,j,' h    ',j)
>             rnorm = abs(gamma(j+1))*norm_fac
>             ratio = rnorm/div0
>             if (ifprint.and.nid.eq.0)
>      $         write (6,66) iter,tolpss,rnorm,div0,ratio,istep
>    66       format(i5,1p4e12.5,i8,' Divergence')
> #ifndef TST_WSCAL
>             if (rnorm .lt. tolpss) goto 900  !converged
> #else
>             if (iter.gt.param(151)-1) goto 900
> #endif
>             if (j.eq.m) goto 1000 !not converged, restart
>             temp = 1./alpha
>             call cmult2(v(1,j+1),w,temp,ntot2)   ! v    = w / alpha
>                                                  !  j+1
>          enddo
>   900    iconv = 1
>  1000    continue
>          !back substitution
>          !     -1
>          !c = H   gamma
>          do k=j,1,-1
>             temp = gamma(k)
>             do i=j,k+1,-1
>                temp = temp - h(k,i)*c(i)
>             enddo
>             c(k) = temp/h(k,k)
>          enddo
>          !sum up Arnoldi vectors
>          do i=1,j
>             call add2s2(x,z(1,i),c(i),ntot2)     ! x = x + c  z
>                                                  !          i  i
>          enddo
> c        if(iconv.eq.1) call dbg_write(x,nx2,ny2,nz2,nelv,'esol',3)
>       enddo
>  9000 continue
> c
>       divex = rnorm
> c     iter = iter - 1
> c
> c     DIAGNOSTICS
> c      call copy(w,x,ntot2)
> c      if (ifvcor) then
> c         xaver = glsc2(bm2,w,ntot2)/volvm2
> c         call cadd(w,-xaver,ntot2)
> c      endif
> c      call copy(r,res,ntot2) !r = res
> c      call cdabdtp(r,w,h1,h2,h2inv,intype)  ! r = A w
> c      do i=1,ntot2
> c         r(i) = res(i) - r(i)               ! r = res - r
> c      enddo
> c      call uzawa_gmres_temp(r,bm2inv,ntot2)
> c                                               !            ______
> c      gamma(1) = sqrt(glsc2(r,r,ntot2)/volvm2) ! gamma  = \/ (r,r)
> c                                               !      1
> c      print *, 'GMRES end resid:',gamma(1)
> c     END DIAGNOSTICS
>       call copy(res,x,ntot2)
> c
>       if (ifvcor) then
>          xaver = glsc2(bm2,res,ntot2)/volvm2
>          call cadd(res,-xaver,ntot2)
>       endif
> c
>       etime1 = dnekclock()-etime1
>       if (nid.eq.0) write(6,9999) istep,iter,divex,tolpss,div0,etime_p,
>      &                            etime1
> c     call flush_hack
>  9999 format(4X,I7,'    U-Pres gmres:   ',I6,1p5E13.4)
> c
> c
>       return
>       end
>       subroutine uzawa_gmres_split0(l,u,b,binv,n)
>       integer n
>       real l(n),u(n),b(n),binv(n)
>       integer i
>       do i=1,n
>          l(i)=sqrt(binv(i))
>          u(i)=sqrt(b(i))
>          if(abs(u(i)*l(i)-1.0).gt.1e-13) print *, i, u(i)*l(i)
>       enddo
>       return
>       end
>       subroutine uzawa_gmres_split(l,u,b,binv,n)
>       integer n
>       integer i
>       do i=1,n
> c        l(i)=sqrt(binv(i))
> c        u(i)=sqrt(b(i))
> c        u(i)=sqrt(b(i))
> c        l(i)=1./u(i)
>          l(i)=1.
>          u(i)=1./l(i)
> c        if(abs(u(i)*l(i)-1.0).gt.1e-13)write(6,*) i,u(i)*l(i),' gmr_sp'
>       enddo
>       return
>       end
>       subroutine uzawa_gmres_temp(a,b,n)
>       integer n
>       real a(n),b(n)
>       integer i
>       do i=1,n
>          a(i)=sqrt(b(i))*a(i)
>       enddo
>       return
>       end
>       subroutine ax(w,x,h1,h2,n)
>       include 'SIZE'
>       include 'TOTAL'
> c
> c     w = A*x for pressure iteration
> c
>       integer n
>       real w(n),x(n),h1(n),h2(n)
>       imsh = 1
>       isd  = 1
>       call axhelm (w,x,h1,h2,imsh,isd)
>       call dssum  (w,nx1,ny1,nz1)
>       call col2   (w,pmask,n)
>       return
>       end
>       subroutine hmh_gmres(res,h1,h2,wt,iter)
> c     Solve the Helmholtz equation by right-preconditioned c     GMRES
> iteration.
>       include 'SIZE'
>       include 'TOTAL'
>       include 'FDMH1'
>       include 'GMRES'
>       logical          ifprint
>       real             res  (lx1*ly1*lz1*lelv)
>       real             wt   (lx1,ly1,lz1,lelv)
>       common /scrcg/ d(lx1*ly1*lz1*lelv),wk(lx1*ly1*lz1*lelv)
>       real alpha, l, temp
>       integer j,m
>       logical iflag
>       save    iflag
>       real    norm_fac
>       save    norm_fac
>       n = nx1*ny1*nz1*nelv
>       etime_p = 0.
>       divex = 0.
>       iter  = 0
>       m     = lgmres
>       if(.not.iflag) then
>          iflag=.true.
>          call uzawa_gmres_split(ml,mu,bm1,binvm1,nx1*ny1*nz1*nelv)
>          norm_fac = 1./sqrt(volvm1)
>       endif
>       call set_fdm_prec_h1b(d,h1,h2,nelv)
>       if (ifvcor) smean = -1./glsum(vmult,n)
>       call chktcg1(tolps,res,h1,h2,pmask,vmult,1,1)
>       tolpss = tolps
> c
>       iconv = 0
>       call rzero(x,n)
>       do while(iconv.eq.0.and.iter.lt.500)
>          if(iter.eq.0) then               !      -1
>             call col3(r,ml,res,n)         ! r = L  res
> c           call copy(r,res,n)
>          else
>             !update residual
>             call copy  (r,res,n)                  ! r = res
>             call ax    (w,x,h1,h2,n)              ! w = A x
>             call add2s2(r,w,-1.,n)                ! r = r - w
>                                                   !      -1
>             call col2(r,ml,n)                     ! r = L   r
>          endif
>                                                   !            ______
>          gamma(1) = sqrt(glsc3(r,r,wt,n))         ! gamma  = \/ (r,r)
>                                                   !      1
>          if(iter.eq.0) then
>          endif
>          rnorm = 0.
>          temp = 1./gamma(1)
>          call cmult2(v(1,1),r,temp,n)             ! v  = r / gamma
>                                                   !  1            1
>          do j=1,m
>             iter = iter+1
>                                                   !       -1
>             call col3(w,mu,v(1,j),n)              ! w  = U   v
>                                                   !           j
> c . . . . . Overlapping Schwarz + coarse-grid . . . . . . .
>             kfldfdm = ndim+1
>             call fdm_h1
>      $           (z(1,j),w,d,pmask,vmult,nelv,ktype(1,1,kfldfdm),wk)
>             call crs_solve_h1 (wk,w) c           call
>                                                   !  j
>             call add2         (z(1,j),wk,n)
>             if (ifvcor) then
>                rmean = smean*glsc2(z(1,j),vmult,n)
>                call cadd(z(1,j),rmean,n)
>             endif
> c . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
>             call ax  (w,z(1,j),h1,h2,n)           ! w = A z
>                                                   !        j
>                                                   !      -1
>             call col2(w,ml,n)                     ! w = L   w
> c           do i=1,j
> c              h(i,j)=glsc3(w,v(1,i),wt,n)        ! h    = (w,v )
> c                                                 !  i,j       i
> c              call add2s2(w,v(1,i),-h(i,j),n)    ! w = w - h    v
> c           enddo                                 !          i,j  i
>             do i=1,j
>                h(i,j)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
>             enddo                                 !  i,j       i
>             do i=1,j
>             enddo                                 !          i,j  i
> c
> c           do i=1,j
> c              wk1(i)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
> c           enddo                                 !  i,j       i
> c                                                 !
> c
> c           do i=1,j
> c              call add2s2(w,v(1,i),-wk1(i),n)    ! w = w - h    v
> c           enddo
>             do i=1,j-1
>                temp = h(i,j)
>             enddo
>                                                  !            ______
>             alpha = sqrt(glsc3(w,w,wt,n))        ! alpha =  \/ (w,w)
>             rnorm = 0.
>             temp = 1./l
>             s(j) = alpha  * temp
>             h(j,j) = l
>             ratio = rnorm/div0
> #ifndef TST_WSCAL
> #else
> #endif
>             temp = 1./alpha
>             call cmult2(v(1,j+1),w,temp,n)   ! v    = w / alpha
>                                              !  j+1
>          enddo
>   900    iconv = 1
>  1000    continue
>          !back substitution
>          !     -1
>          !c = H   gamma
>          do k=j,1,-1
>             temp = gamma(k)
>             do i=j,k+1,-1
>             enddo
>             c(k) = temp/h(k,k)
>          enddo
>          do i=1,j
>             call add2s2(x,z(1,i),c(i),n)     ! x = x + c  z
>          enddo                               !          i  i
> c        if(iconv.eq.1) call dbg_write(x,nx1,ny1,nz1,nelv,'esol',3)
>       enddo
>  9000 continue
> c
>       divex = rnorm
>       call copy(res,x,n)
> c
>       if (ifvcor) then
>          xaver = glsc2(bm1,res,n)/volvm1
>          call cadd(res,-xaver,n)
>       endif
> c
>      &                            etime1
> c     call flush_hack
>  9999 format(4X,I7,'    PRES gmres:   ',I6,1p5E13.4)
>       return
>       end
