[Nek5000-users] compilation, large memory
Fri Apr 23 07:08:47 CDT 2010
Hi Frank,
Are you running in parallel?   How many processors, and how
many elements in the problem of interest?
If you have, say, 120 elements, and are running on 4 processors,
you can set lelt=30, which would reduce your per-processor-memory
footprint by a factor of 4.
Cheers,
Paul
On Fri, 23 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
I am having a problem compiling on an x86_64 system.  Smaller problems
work fine.  My SIZE file starts out with:
       parameter (ldim=3)
       parameter (lx1=6*4,ly1=lx1,lz1=lx1,lelt=120,lelv=lelt)
       parameter (lxd=9*4,lyd=lxd,lzd=lxd)
The error message is:
/home/fmuldoo/programs/mpich2-1.2.1p1-intel/bin/mpif77 -mcmodel=medium
-shared-intel -c  -O2 -r8 -fpconstant -fpp -DMPI -DLONGINT8
-I/home/fmuldoo/programs/nek5000/nek5/trunk/nek
-I/data/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim7/AR-.66-RE-1800-PR-04.0-dt-6.0e-5-time-006.0-grid-3-Intel /data/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim7/AR-.66-RE-1800-PR-04.0-dt-6.0e-5-time-006.0-grid-3-Intel/delet.f -o delet.o
-shared-intel -o nek5000  delet.o drive.o drive1.o drive2.o plan4.o
bdry.o coef.o conduct.o connect1.o connect2.o dssum.o edgec.o eigsolv.o
gauss.o genxyz.o navier1.o navier0.o navier2.o navier3.o navier4.o
prepost.o speclib.o map2.o turb.o mvmesh.o ic.o ssolv.o planx.o math.o
mxm_wrapper.o hmholtz.o gfdm_par.o  gfdm_op.o gfdm_solve.o subs1.o
subs2.o genbox.o gmres.o hsmg.o convect.o induct.o perturb.o navier5.o
navier6.o navier7.o navier8.o fast3d.o fasts.o calcz.o byte.o chelpers.o
byte_mpi.o postpro.o cvode_driver.o cvode_aux.o setprop.o qthermal.o
makeq.o papi.o ssygv.o dsygv.o mxm_std.o blas.o   comm_mpi.o jl2_gs.o
jl2_sort.o jl2_sarray_transfer.o jl2_sarray_sort.o jl2_gs_local.o
jl2_crystal.o jl2_comm.o jl2_tensor.o jl2_fail.o jl2_fcrystal.o
jl_tuple_list.o jl_transfer.o jl_sort.o jl_fcrystal.o jl_errmem.o
jl_crystal.o jl_findpts.o jl_pfindpt.o jl_tensor.o jl_findpt.o jl_poly.o
jl2_sparse_cholesky.o jl2_xxt.o jl2_fcrs.o
/home/fmuldoo/programs/mpich2-1.2.1p1-intel/lib/libmpich.a(setbotf.o):
In function `mpirinitf_':
setbotf.f:(.text+0xd): relocation truncated to fit: R_X86_64_32 against
symbol `mpipriv1_' defined in COMMON section in comm_mpi.o
setbotf.f:(.text+0x12): relocation truncated to fit: R_X86_64_32 against
setbotf.f:(.text+0x17): relocation truncated to fit: R_X86_64_32 against
setbotf.f:(.text+0x1c): relocation truncated to fit: R_X86_64_32 against
symbol `mpipriv2_' defined in COMMON section in comm_mpi.o
setbotf.f:(.text+0x22): relocation truncated to fit: R_X86_64_32 against
setbotf.f:(.text+0x28): relocation truncated to fit: R_X86_64_32 against
symbol `mpiprivc_' defined in COMMON section in comm_mpi.o
setbotf.f:(.text+0x34): relocation truncated to fit: R_X86_64_32 against
make: *** [nek5000] Error 1
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
