[Nek5000-users] Detected non-right-handed element..
Thu Apr 22 08:12:31 CDT 2010
I was having trouble with "non-right-handed element" warning for a BFS
case. Then I tried running the example case "fs_2" with repo. version 491
and got the same error as given below. This works just fine with repo.
verison 486. The code is compiled with GNU compiler.
WARNINGa: Detected non-right-handed element.
  Number       1  C1-4: -0.3000E+00 -0.3000E+00  0.0000E+00  0.0000E+00
Find attached the logfile for your reference.
Harish
On Wed, April 21, 2010 3:59 pm, nek5000-users at lists.mcs.anl.gov wrote:
> Shriram,
> Can you post or send a gzip'd copy of your .rea/.usr file?
> Thanks,
> Paul
> On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello,
>> In the latest repo (491), I get the following error :
>> <code>
>>  WARNINGb: Detected non-right-handed element.
>>  Number       1  V1-8: -0.2133E-01 -0.2133E-01  0.0000E+00  0.0000E+00
>>                     0.9570E-03  0.9570E-03  0.9570E-03  0.9570E-03
>> call exitt: dying ...
>> </code>
>> However, the version I was using previously (479) did not have any
>> problem
>> while compiling or during simulations. Any thoughts ?
>> Thanks for any help..
>> Regards
>> Shriram
> Nek5000-users mailing list
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100422/386bbcf6/attachment.obj>
