[Nek5000-users] Nekmerge question
Thu Apr 22 08:01:57 CDT 2010
Did you remove your old object files? Run 'maketools clean' to be sure.
Stefan
On Apr 22, 2010, at 2:52 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Well, it did'nt change much.
> mxm.f(54): (col. 13) remark: LOOP WAS VECTORIZED.
> gcc -mcmodel=medium -c -DUNDERSCORE -Dr8 xdriver.c
> xdriver.c: In function ‘TypeChar’:
> xdriver.c:759:  warning: comparison is always true due to limited range of data type
> ifort -mcmodel=medium -o /home/loiseau/BricoNek/cylindre/prex prenek.o curve.o edit.o build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o xdriver.o  -L/usr/X11R6/lib -lX11 -lm
> xdriver.o: In function `SetUpEnv':
> xdriver.c:(.text+0xec): relocation truncated to fit: R_X86_64_32S against symbol `Line' defined in COMMON section in xdriver.o
> xdriver.o: In function `advanceLine':
> xdriver.c:(.text+0x12d9): relocation truncated to fit: R_X86_64_32S against symbol `Line' defined in COMMON section in xdriver.o
> xdriver.o: In function `puts_':
> xdriver.c:(.text+0x1523): relocation truncated to fit: R_X86_64_32S against symbol `Line' defined in COMMON section in xdriver.o
> xdriver.c:(.text+0x155c): relocation truncated to fit: R_X86_64_32S against symbol `Line' defined in COMMON section in xdriver.o
> xdriver.o: In function `TypeChar':
> xdriver.c:(.text+0x17f9): relocation truncated to fit: R_X86_64_32S against symbol `Line' defined in COMMON section in xdriver.o
> /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__message_catalog_close':
> for_diags_intel.c:(.text+0x17): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o)
> /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__io_return':
> for_diags_intel.c:(.text+0xb10): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o)
> for_diags_intel.c:(.text+0xbd8): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o)
> for_diags_intel.c:(.text+0xc29): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o)
> /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o): In function `for__issue_diagnostic':
> for_diags_intel.c:(.text+0xd58): relocation truncated to fit: R_X86_64_PC32 against symbol `message_catalog' defined in COMMON section in /opt/intel/Compiler/11.0/074/lib/intel64/libifcore.a(for_diags_intel.o)
> for_diags_intel.c:(.text+0xdc0): additional relocation overflows omitted from the output
> make[1]: *** [prex] Erreur 1
> make[1]: quittant le répertoire « /home/loiseau/nek5_svn/trunk/tools/prenek »
> make: *** [all] Erreur 1
> Nek5000-users mailing list
