[Nek5000-users] Residuals for post-processing
Wed Apr 21 09:27:12 CDT 2010
Hi Markus,
pressure residuals are in gmres
You could output them via:
     call outpost(x,y,z,res,t,'res')
where x,y,z,t are arrays of your choice and res
is the array you want to look at.
Nek will convert the res mesh to the velocity mesh
if needed.  I usually follow such a call with
     call exitti('quit in gmres$',n)
because prepost() uses some scratch common blocks
that are potentially shared with the calling routine
(not in the case of gmres, I think...) -- so data
might be corrupted after such a call.   The idea of
prepost was to be called in between timesteps, when
such memory re-use would be admissable.   The alternative
would be to define your own storage in a common block,
save the residuals to this locale, then loop through
calls to outpost in userchk afterwards...  I've done
that in the past.
All this being said, I'm not 100% certain that the
iterative solvers is the place to look for the difficulty.
Most problems arise from spatial resolution issues...or
temporal stability problems.  The latter can be identified
by drastic reduction in dt.
What exactly is blowing up for you?
Paul
On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> I'd like to save the residuals for the pressure iterations (PN/PN-2 as well
> as PN/PN) into a scalar variable (scalar 0, instead of temperature say) for
> each grid point in order to see where my solution diverges.
> Is there a way to add something to the .usr file to do that? I couldn't find
> the variable in the code and also wouldn't know how to save something from
> the lx2=lx1-2 grid onto the lx1 grid.
> Would this also be possible with the velocity residuals?
> Thanks,
> Markus
> Nek5000-users mailing list
uuuu
c-----------------------------------------------------------------------
       subroutine uzawa_gmres(res,h1,h2,h2inv,intype,iter)
c     Solve the pressure equation by right-preconditioned
c     GMRES iteration.
c     intype =  0  (steady)
c     intype =  1  (explicit)
c     intype = -1  (implicit)
       include 'SIZE'
       include 'TOTAL'
       include 'GMRES'
       common  /ctolpr/ divex
       common  /cprint/ ifprint
       logical          ifprint
       real             res  (lx2*ly2*lz2*lelv)
       real             h1   (lx1,ly1,lz1,lelv)
       real             h2   (lx1,ly1,lz1,lelv)
       real             h2inv(lx1,ly1,lz1,lelv)
       common /scrmg/    wp (lx2,ly2,lz2,lelv)
       common /ctmp0/   wk1(lgmres),wk2(lgmres)
       common /cgmres1/ y(lgmres)
       real alpha, l, temp
       integer j,m
c
       logical iflag
       save    iflag
       data    iflag /.false./
       real    norm_fac
       save    norm_fac
c
       real*8 etime1,dnekclock
c
       if(.not.iflag) then
          iflag=.true.
          call uzawa_gmres_split0(ml,mu,bm2,bm2inv,nx2*ny2*nz2*nelv)
          norm_fac = 1./sqrt(volvm2)
       endif
c
       etime1 = dnekclock()
       etime_p = 0.
       divex = 0.
       iter  = 0
       m = lgmres
c
       call chktcg2(tolps,res,iconv)
       if (param(21).gt.0.and.tolps.gt.abs(param(21)))
      $   tolps = abs(param(21))
c     if (param(21).lt.0) tolps = abs(param(21))
       if (istep.eq.0) tolps = 1.e-4
       tolpss = tolps
c
       ntot2  = nx2*ny2*nz2*nelv
c
       iconv = 0
       call rzero(x,ntot2)
       do while(iconv.eq.0.and.iter.lt.100)
          if(iter.eq.0) then
                                                   !      -1
             call col3(r,ml,res,ntot2)             ! r = L  res
c           call copy(r,res,ntot2)
          else
             !update residual
             call copy(r,res,ntot2)                ! r = res
             call cdabdtp(w,x,h1,h2,h2inv,intype)  ! w = A x
             call add2s2(r,w,-1.,ntot2)            ! r = r - w
                                                   !      -1
             call col2(r,ml,ntot2)                 ! r = L   r
          endif
                                                   !            ______
          gamma(1) = sqrt(glsc2(r,r,ntot2))        ! gamma  = \/ (r,r)
                                                   !      1
          if(iter.eq.0) then
             div0 = gamma(1)*norm_fac
             if (param(21).lt.0) tolpss=abs(param(21))*div0
          endif
          !check for lucky convergence
          rnorm = 0.
          if(gamma(1) .eq. 0.) goto 9000
          temp = 1./gamma(1)
          call cmult2(v(1,1),r,temp,ntot2)         ! v  = r / gamma
                                                   !  1            1
          do j=1,m
             iter = iter+1
                                                   !       -1
             call col3(w,mu,v(1,j),ntot2)          ! w  = U   v
                                                   !           j
             etime2 = dnekclock()
             if(param(43).eq.1) then
                call uzprec(z(1,j),w,h1,h2,intype,wp)
             else                                  !       -1
                call hsmg_solve(z(1,j),w)          ! z  = M   w
             endif
             etime_p = etime_p + dnekclock()-etime2
             call cdabdtp(w,z(1,j),                ! w = A z
      $                   h1,h2,h2inv,intype)      !        j
                                                   !      -1
             call col2(w,ml,ntot2)                 ! w = L   w
c           !modified Gram-Schmidt
c           do i=1,j
c              h(i,j)=glsc2(w,v(1,i),ntot2)       ! h    = (w,v )
c                                                 !  i,j       i
c              call add2s2(w,v(1,i),-h(i,j),ntot2)! w = w - h    v
c           enddo                                 !          i,j  i
c           2-PASS GS, 1st pass:
             do i=1,j
                h(i,j)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
             enddo                                 !  i,j       i
             call gop(h(1,j),wk1,'+  ',j)          ! sum over P procs
             do i=1,j
             enddo                                 !          i,j  i
c           2-PASS GS, 2nd pass:
c
c           do i=1,j
c              wk1(i)=vlsc2(w,v(1,i),ntot2)       ! h    = (w,v )
c           enddo                                 !  i,j       i
c                                                 !
c           call gop(wk1,wk2,'+  ',j)             ! sum over P procs
c
c           do i=1,j
c              call add2s2(w,v(1,i),-wk1(i),ntot2)! w = w - h    v
c              h(i,j) = h(i,j) + wk1(i)           !          i,j  i
c           enddo
             !apply Givens rotations to new column
             do i=1,j-1
                temp = h(i,j)
                h(i  ,j)=  c(i)*temp + s(i)*h(i+1,j)
                h(i+1,j)= -s(i)*temp + c(i)*h(i+1,j)
             enddo
                                                   !            ______
             alpha = sqrt(glsc2(w,w,ntot2))        ! alpha =  \/ (w,w)
             rnorm = 0.
             if(alpha.eq.0.) goto 900  !converged
             l = sqrt(h(j,j)*h(j,j)+alpha*alpha)
             temp = 1./l
             c(j) = h(j,j) * temp
             s(j) = alpha  * temp
             h(j,j) = l
             gamma(j+1) = -s(j) * gamma(j)
             gamma(j)   =  c(j) * gamma(j)
c            call outmat(h,m,j,' h    ',j)
             rnorm = abs(gamma(j+1))*norm_fac
             ratio = rnorm/div0
             if (ifprint.and.nid.eq.0)
      $         write (6,66) iter,tolpss,rnorm,div0,ratio,istep
    66       format(i5,1p4e12.5,i8,' Divergence')
#ifndef TST_WSCAL
             if (rnorm .lt. tolpss) goto 900  !converged
#else
             if (iter.gt.param(151)-1) goto 900
#endif
             if (j.eq.m) goto 1000 !not converged, restart
             temp = 1./alpha
             call cmult2(v(1,j+1),w,temp,ntot2)   ! v    = w / alpha
                                                  !  j+1
          enddo
   900    iconv = 1
  1000    continue
          !back substitution
          !     -1
          !c = H   gamma
          do k=j,1,-1
             temp = gamma(k)
             do i=j,k+1,-1
                temp = temp - h(k,i)*c(i)
             enddo
             c(k) = temp/h(k,k)
          enddo
          !sum up Arnoldi vectors
          do i=1,j
             call add2s2(x,z(1,i),c(i),ntot2)     ! x = x + c  z
                                                  !          i  i
          enddo
c        if(iconv.eq.1) call dbg_write(x,nx2,ny2,nz2,nelv,'esol',3)
       enddo
  9000 continue
c
       divex = rnorm
c     iter = iter - 1
c
c     DIAGNOSTICS
c      call copy(w,x,ntot2)
c      if (ifvcor) then
c         xaver = glsc2(bm2,w,ntot2)/volvm2
c         call cadd(w,-xaver,ntot2)
c      endif
c      call copy(r,res,ntot2) !r = res
c      call cdabdtp(r,w,h1,h2,h2inv,intype)  ! r = A w
c      do i=1,ntot2
c         r(i) = res(i) - r(i)               ! r = res - r
c      enddo
c      call uzawa_gmres_temp(r,bm2inv,ntot2)
c                                               !            ______
c      gamma(1) = sqrt(glsc2(r,r,ntot2)/volvm2) ! gamma  = \/ (r,r)
c                                               !      1
c      print *, 'GMRES end resid:',gamma(1)
c     END DIAGNOSTICS
       call copy(res,x,ntot2)
c
       if (ifvcor) then
          xaver = glsc2(bm2,res,ntot2)/volvm2
          call cadd(res,-xaver,ntot2)
       endif
c
       etime1 = dnekclock()-etime1
       if (nid.eq.0) write(6,9999) istep,iter,divex,tolpss,div0,etime_p,
      &                            etime1
c     call flush_hack
  9999 format(4X,I7,'    U-Pres gmres:   ',I6,1p5E13.4)
c
c
       return
       end
       subroutine uzawa_gmres_split0(l,u,b,binv,n)
       integer n
       real l(n),u(n),b(n),binv(n)
       integer i
       do i=1,n
          l(i)=sqrt(binv(i))
          u(i)=sqrt(b(i))
          if(abs(u(i)*l(i)-1.0).gt.1e-13) print *, i, u(i)*l(i)
       enddo
       return
       end
       subroutine uzawa_gmres_split(l,u,b,binv,n)
       integer n
       integer i
       do i=1,n
c        l(i)=sqrt(binv(i))
c        u(i)=sqrt(b(i))
c        u(i)=sqrt(b(i))
c        l(i)=1./u(i)
          l(i)=1.
          u(i)=1./l(i)
c        if(abs(u(i)*l(i)-1.0).gt.1e-13)write(6,*) i,u(i)*l(i),' gmr_sp'
       enddo
       return
       end
       subroutine uzawa_gmres_temp(a,b,n)
       integer n
       real a(n),b(n)
       integer i
       do i=1,n
          a(i)=sqrt(b(i))*a(i)
       enddo
       return
       end
       subroutine ax(w,x,h1,h2,n)
       include 'SIZE'
       include 'TOTAL'
c
c     w = A*x for pressure iteration
c
       integer n
       real w(n),x(n),h1(n),h2(n)
       imsh = 1
       isd  = 1
       call axhelm (w,x,h1,h2,imsh,isd)
       call dssum  (w,nx1,ny1,nz1)
       call col2   (w,pmask,n)
       return
       end
       subroutine hmh_gmres(res,h1,h2,wt,iter)
c     Solve the Helmholtz equation by right-preconditioned
c     GMRES iteration.
       include 'SIZE'
       include 'TOTAL'
       include 'FDMH1'
       include 'GMRES'
       logical          ifprint
       real             res  (lx1*ly1*lz1*lelv)
       real             wt   (lx1,ly1,lz1,lelv)
       common /scrcg/ d(lx1*ly1*lz1*lelv),wk(lx1*ly1*lz1*lelv)
       real alpha, l, temp
       integer j,m
       logical iflag
       save    iflag
       real    norm_fac
       save    norm_fac
       n = nx1*ny1*nz1*nelv
       etime_p = 0.
       divex = 0.
       iter  = 0
       m     = lgmres
       if(.not.iflag) then
          iflag=.true.
          call uzawa_gmres_split(ml,mu,bm1,binvm1,nx1*ny1*nz1*nelv)
          norm_fac = 1./sqrt(volvm1)
       endif
       call set_fdm_prec_h1b(d,h1,h2,nelv)
       if (ifvcor) smean = -1./glsum(vmult,n)
       call chktcg1(tolps,res,h1,h2,pmask,vmult,1,1)
       tolpss = tolps
c
       iconv = 0
       call rzero(x,n)
       do while(iconv.eq.0.and.iter.lt.500)
          if(iter.eq.0) then               !      -1
             call col3(r,ml,res,n)         ! r = L  res
c           call copy(r,res,n)
          else
             !update residual
             call copy  (r,res,n)                  ! r = res
             call ax    (w,x,h1,h2,n)              ! w = A x
             call add2s2(r,w,-1.,n)                ! r = r - w
                                                   !      -1
             call col2(r,ml,n)                     ! r = L   r
          endif
                                                   !            ______
          gamma(1) = sqrt(glsc3(r,r,wt,n))         ! gamma  = \/ (r,r)
                                                   !      1
          if(iter.eq.0) then
          endif
          rnorm = 0.
          temp = 1./gamma(1)
          call cmult2(v(1,1),r,temp,n)             ! v  = r / gamma
                                                   !  1            1
          do j=1,m
             iter = iter+1
                                                   !       -1
             call col3(w,mu,v(1,j),n)              ! w  = U   v
                                                   !           j
c . . . . . Overlapping Schwarz + coarse-grid . . . . . . .
             kfldfdm = ndim+1
             call fdm_h1
      $           (z(1,j),w,d,pmask,vmult,nelv,ktype(1,1,kfldfdm),wk)
             call crs_solve_h1 (wk,w)
c           call hsmg_solve(z(1,j),w)             ! z  = M   w
                                                   !  j
             call add2         (z(1,j),wk,n)
             if (ifvcor) then
                rmean = smean*glsc2(z(1,j),vmult,n)
                call cadd(z(1,j),rmean,n)
             endif
c . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
             call ax  (w,z(1,j),h1,h2,n)           ! w = A z
                                                   !        j
                                                   !      -1
             call col2(w,ml,n)                     ! w = L   w
c           do i=1,j
c              h(i,j)=glsc3(w,v(1,i),wt,n)        ! h    = (w,v )
c                                                 !  i,j       i
c              call add2s2(w,v(1,i),-h(i,j),n)    ! w = w - h    v
c           enddo                                 !          i,j  i
             do i=1,j
                h(i,j)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
             enddo                                 !  i,j       i
             do i=1,j
             enddo                                 !          i,j  i
c
c           do i=1,j
c              wk1(i)=vlsc3(w,v(1,i),wt,n)        ! h    = (w,v )
c           enddo                                 !  i,j       i
c                                                 !
c
c           do i=1,j
c              call add2s2(w,v(1,i),-wk1(i),n)    ! w = w - h    v
c           enddo
             do i=1,j-1
                temp = h(i,j)
             enddo
                                                  !            ______
             alpha = sqrt(glsc3(w,w,wt,n))        ! alpha =  \/ (w,w)
             rnorm = 0.
             temp = 1./l
             s(j) = alpha  * temp
             h(j,j) = l
             ratio = rnorm/div0
#ifndef TST_WSCAL
#else
#endif
             temp = 1./alpha
             call cmult2(v(1,j+1),w,temp,n)   ! v    = w / alpha
                                              !  j+1
          enddo
   900    iconv = 1
  1000    continue
          !back substitution
          !     -1
          !c = H   gamma
          do k=j,1,-1
             temp = gamma(k)
             do i=j,k+1,-1
             enddo
             c(k) = temp/h(k,k)
          enddo
          do i=1,j
             call add2s2(x,z(1,i),c(i),n)     ! x = x + c  z
          enddo                               !          i  i
c        if(iconv.eq.1) call dbg_write(x,nx1,ny1,nz1,nelv,'esol',3)
       enddo
  9000 continue
c
       divex = rnorm
       call copy(res,x,n)
c
       if (ifvcor) then
          xaver = glsc2(bm1,res,n)/volvm1
          call cadd(res,-xaver,n)
       endif
c
      &                            etime1
c     call flush_hack
  9999 format(4X,I7,'    PRES gmres:   ',I6,1p5E13.4)
       return
       end
