[Nek5000-users] makenek, sun complier & mpi
Wed Apr 21 07:04:31 CDT 2010
Hi Stefan,
I have tried both mpich-1.2.7p1 and mpich2-1.2.1p1.  Same problem
though.
On Wed, 2010-04-21 at 14:00 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> What MPI implementation are you using?
> Stefan
> On Apr 21, 2010, at 1:58 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello all,
> > I am seeing the following error message when I use an mpif77 and mpicc
> > that use the Sun compilers.  Everything is fine if in makenek F77=sunf95
> > and CC=suncc (and IFMPI="false"), or if using mpif77 and mpicc that use
> > the Intel compilers.
> > Cheers,
> > Frank
> > sunf95: Warning: Option -showme passed to ld, if ld is invoked, ignored
> > otherwise
> > Usage: sunf95 [ options ] files.  Use 'sunf95 -flags' for details
> > WARNING: Cannot detect compiler specfic flags
> >      echo  - to promote REAL to 8 bytes
> >      echo  - to invoke preprocessor first
> > Please edit the makefile and specify the requested compiler flags in the
> > P variable!
> > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> > Technische Universität Wien (Technical University of Vienna)
> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> > Mechanics and Heat Transfer)
> > Resselgasse 3
> > 1040 Wien
> > Tel: +4315880132232
> > Fax: +4315880132299
> > Cell:+436765203470
> > fmuldoo (skype)
> > http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
