[Nek5000-users] SETDTC message
Mon Apr 19 16:27:50 CDT 2010
Hi Frank,
Set DT < 0 (param 12 in .rea file) and then dt = |param(12)| for
the duration of the run.  (Sometimes you still get the message though...)
Paul
On Mon, 19 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
I am coming across the following message "Problem calculating new DT
Discriminant" in subroutine "SETDTC" where a new timestep based on the
CFL condition is computed.  Aside from what the message means, how can
one turn off variable time stepping (which I assume is occurring since
this subroutine is being called).
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
