[Nek5000-users] *.fld files to ...
Mon Apr 19 11:02:40 CDT 2010
Yes you're right the export capabilities to TecPlot are quite limited (no multizone support, etc.).
If you know the data layout of NEK it's quite easy write your own convert.
We did that for TecPlot some time ago.
Stefan
On Apr 19, 2010, at 5:57 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Stefan,
> Thanks.  I had tried that.  This translator appears to be a fairly rough
> attempt to output data in Tecplot's format.  It at times writes out
> files that Tecplot cannot read.  In addition, if dealing with temporal
> data, there appears to be no way to write out the data at each time step
> to a single Tecplot file.  Therefore, one would need to do this
> (exporting through the menus) for every file at every time step.
> Cheers,
> Frank
> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Frank,
>> read your data into VisIt and use the export option.
>> I don't recall exactly what output formats they support but there are quite a few.
>> Stefan
>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello all,
>>> Does anyone know of a way to translate *.fld files to a different format
>>> (perhaps such as HDF, CGNS, Plot3D etc.)?
>>> Cheers,
>>> Frank
>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>> Technische Universität Wien (Technical University of Vienna)
>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>> Mechanics and Heat Transfer)
>>> Resselgasse 3
>>> 1040 Wien
>>> Tel: +4315880132232
>>> Fax: +4315880132299
>>> Cell:+436765203470
>>> fmuldoo (skype)
>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
