[Nek5000-users] linking
Thu Apr 15 14:41:06 CDT 2010
Hello all,
I am coming across a linking problem.  When using the below linking
fails.
      parameter (lx1=8*5...
      parameter (lxd=12*5...
But this is OK:
      parameter (lx1=8*4...
      parameter (lxd=12*4...
The error message is:
sunf95 -c  -O2 -r8const -xtypemap=real:64 -fpp -DLONGINT8
-I/home/fmuldoo/programs/nek5000/nek5/trunk/nek
-I/data/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim4 /data/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/sim4/openboat.f -o openboat.o
sunf95 -o nek5000  openboat.o drive.o drive1.o drive2.o plan4.o bdry.o
coef.o conduct.o connect1.o connect2.o dssum.o edgec.o eigsolv.o gauss.o
genxyz.o navier1.o navier0.o navier2.o navier3.o navier4.o prepost.o
speclib.o map2.o turb.o mvmesh.o ic.o ssolv.o planx.o math.o
mxm_wrapper.o hmholtz.o gfdm_par.o  gfdm_op.o gfdm_solve.o subs1.o
subs2.o genbox.o gmres.o hsmg.o convect.o induct.o perturb.o navier5.o
navier6.o navier7.o navier8.o fast3d.o fasts.o calcz.o byte.o chelpers.o
byte_mpi.o postpro.o cvode_driver.o cvode_aux.o setprop.o qthermal.o
makeq.o papi.o ssygv.o dsygv.o mxm_std.o blas.o   comm_mpi.o mpi_dummy.o
jl2_gs.o jl2_sort.o jl2_sarray_transfer.o jl2_sarray_sort.o
jl2_gs_local.o jl2_crystal.o jl2_comm.o jl2_tensor.o jl2_fail.o
jl2_fcrystal.o jl_tuple_list.o jl_transfer.o jl_sort.o jl_fcrystal.o
jl_errmem.o jl_crystal.o jl_findpts.o jl_pfindpt.o jl_tensor.o
jl_findpt.o jl_poly.o jl2_sparse_cholesky.o jl2_xxt.o jl2_fcrs.o
bdry.o: In function `bcneutr_':
bdry.f:(.text+0x6885): relocation truncated to fit: R_X86_64_PC32
against symbol `ctmp0_' defined in COMMON section in navier5.o
bdry.f:(.text+0x68c1): relocation truncated to fit: R_X86_64_PC32
bdry.o: In function `trstax_':
bdry.f:(.text+0x759c): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x75a3): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x75cd): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x75de): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x75f6): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x7607): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x7630): relocation truncated to fit: R_X86_64_PC32
bdry.f:(.text+0x7641): relocation truncated to fit: R_X86_64_PC32
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
