[Nek5000-users] Possible bug "navier1.f"
Sun Apr 11 19:15:50 CDT 2010
Thanks Frank -
You're correct.  I appears to be in a test routine that
is never used and probably was not updated.
I deleted it so it will get taken care of in the next round.
Paul
On Mon, 12 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
I came across a couple of places where an argument is missing.
       CALL MULTD (TA1,TVX,RXM2,SXM2,TXM2,1)
"/home/fmuldoo/nek5_svn/trunk/nek/navier1.f", Line = 2548, Column = 7:
WARNING: Procedure "MULTD" is defined at line 564
(/home/fmuldoo/nek5_svn/trunk/nek/navier1.f) and has 7 dummy
argument(s).  This reference has 6 actual argument(s) specified.
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
