[Nek5000-users] Seg. fault in running a backward facing step case.
Fri Apr 9 11:12:13 CDT 2010
Thanks for the help!!
Harish
On Fri, 9 Apr 2010 nek5000-users at lists.mcs.anl.gov wrote:
> Yes that's true. I'll discuss with the other developers how this can be improved. Also we're working on a fix to avoid the SEGFAULT.
> Stefan
> On Apr 9, 2010, at 6:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hi Stefan,
> > Thanks for your reply. Compiling with with a larger lelt and OIFS on the code worked.
> > So what I understand from your reply is that if OIFS is ON the code requires more memory
> > and it should be compiled with more lelt rather than the exact lelt=lelg/lp.
> > Harish.
> >> Harish,
> >> when we try to exit the code with an error message the code crashes. You turned on OIFS (T IFCHAR) but you don't have enough memory available. I think you can just increase lelt to avoid this problem. Anyway the code should print out a reasonable err-msg and not a SEGFAULT!
> >> Stefan
> >> On Apr 9, 2010, at 4:33 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> Hello,
> >>> I am trying to simulate flow in a 3D backward facing step (BFS) geometry.
> >>> I have attached the *.box file and n2to3.in file that I use to create the
> >>> 3D geometry. For reference logfile, *.rea and *.usr files are attached.
> >>> The code is compiled with GNU compiler and OpenMPI. The code is compiled
> >>> for 16 processors and compiler.out file is attached as well.
> >>> When I run the code, I get a seg. fault. After running the "gdb" tool on
> >>> the core.* file, I get the following output. I have attached the gdb
> >>> output file too.
> >>> Core was generated by `./nek5000'.
> >>> Program terminated with signal 11, Segmentation fault.
> >>> [New process 7652]
> >>> #0  0x0000000000488768 in chcopy_ ()
> >>> 3D BFS geometry has a wall at the bottom and symmetry b.c. at the top. But
> >>> if I change the top b.c. with wall the simulation works. For reference I
> >>> have attached the job output file.
> >>> Initially, I thought the problem was with memory limitations on my cluster
> >>> for a bigger geometry. So I tried a smaller geometry, but I still kept
> >>> getting seg. faults.
> >>> Help with solving this problem will be greatly appreciated. And sorry for
> >>> attaching so many files.
> >>> Thanks,
> >>> Harish.<bfs.box><n2to3.in><logfile><bfs3d.rea><bfs3d.usr><Backstp.2323.o><gdb.output><compiler.out>_______________________________________________
> >>> Nek5000-users mailing list
> >>> Nek5000-users at lists.mcs.anl.gov
> >>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
