[Nek5000-users] Representing Curved Side in any plane
Thu Apr 8 16:40:06 CDT 2010
Hi Paul,
We tried a few simple geometries with the new midpoint feature and did have
some success, however we are also experiencing a new learning curve with the
feature and thought you could shine some light on it.
We tried with only one element and have been successful.  We then tried with
many elements, including all midpoints in the curved side section, and we
received the "vanishing jacobian" error. Next, we tried removing from the curved
side section; internal edges. So, any midpoints on edges that were "interior" to the
geometry.  My best way to explain this would be midpoints which lie on edges that
 do not see a boundary (meaning the edge is shared by elements on all sides.)  This
 left us with only midpoints on the outer surface of the geometry, which we were able
to deform quite nicely. However, we did reach a threshold at which point
we got the "vanishing jacobian" again.
So this brings up two questions:
1.   Is there no support for internal edges, meaning only midpoints on the surface
of the geometry can be deformed? (If so, I think that is not an issue but good
information to have).
2.  Is there a threshold distance from the midpoint to the undeformed edge for it
to work?  Markus ran a case where the following worked:
10  1   0.75000     -0.090000      0.750000       0.00000       0.00000        m
  9  3   0.75000     -0.090000      0.750000       0.00000       0.00000        m
But, below did not.
10  1   0.75000     -0.100000      0.750000       0.00000       0.00000       m
  9  3   0.75000     -0.100000      0.750000       0.00000       0.00000       m
Thanks for any insight you can provide with this and the new feature!
Michael
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Monday, April 5, 2010 10:17:21 PM GMT -06:00 US/Canada Central
Subject: Re: [Nek5000-users] Representing Curved Side in any plane
Hey Paul,
Sounds great! And I think this is exactly what we needed! We will try it tomorrow.
Thanks again,
Michael
Sent: Monday, April 5, 2010 9:29:33 PM GMT -06:00 US/Canada Central
Hi, I've just added the midside-node support to the current svn repo for nek.
Sorry - I thought I had upgraded this in October but apparently had not committed to
the repo then. Hopefully all should work -- I retested my original benchmark w/ this new
version and it is functioning. Please let me know if this now works for you.
You should be able to modify any one of the 12 edges.
Paul
_______________________________________________ Nek5000-users mailing list Nek5000-users at lists.mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100408/14e8255e/attachment.html>
