[Nek5000-users] Marangoni effect
Tue Apr 6 06:58:40 CDT 2010
Hi Frank,
There should be a way to impose the shear, which corresponds to an
inhomogeneous Neumann condition in the stress-formulation.
The precise values would be supplied by the user through userbc --
generally it's a good idea to compute the quantity in userchk and
save this to an array, then de-reference the array values in userbc(),
which is called once per gridpoint per timestep (as opposed to
once per timestep, like userchk).
I'll check to see if I can determine the correct bc flag to enable
this condition.   To be sure, you will need to use the Pn-Pn-2
formulation, with the stress condition turned on.
Unit normal and unit tangent vectors are available for each element
surface, and routines that allow computations with volume-based and
surface-based arrays abound (e.g., compute dot-product of grad T with
unit normal, where former array is volume-based and latter is surface
based).
Note that Nek supporst an ALE free-surface formulation - just fyi
if this is relevant to your problem.
Paul
On Tue, 6 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
Is there a boundary condition that allows one to specify the shear
stress vector in terms of the temperature gradient along the boundary?
The boundary in question is a curved surface in 3D.
If not, do y'all think that is this something that could be done without
extreme difficulty?
Cheers,
Frank
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
