[Nek5000-users] Flow past cylinder
stefanke stefanke at lav.mavt.ethz.ch
Tue Sep 22 07:53:52 CDT 2009
a good meshing tool is really missing in nek5000 but I am afraid there
is _no_ good high-order quad/hex mesher.
In the case of spectral elements you typically end up with big
elements and you really need a high order geometry representation
otherwise you're not really flexible if it comes to meshing. In
addition to it you may run into accuracy issues if you're using a
lower (e.g. 2nd-order) representation of your geometry.
However high-order surface meshing etc. is very difficult for complex
geometries especially for hex meshes. Most of the meshing tools
(Cubit, Gambit, ..) are designed for lower-order methods (e.g.
FEM,FVM) so they're not ideal at all.
Stefan
On Sep 22, 2009, at 12:52 PM, wangzhicheng wrote:
> Hi everyone
> I finally solved the problem of element mismatch that mentioned in
> the previous email. This problem is a result of curves-reading bugs
> in tool sem2nek.
> Semtex is a quadrilateral spectral element DNS code that has a mesh
> converter from  Gambit mesh generator and a tool---sem2nek, which
> converter mesh format from semtex to nekton format.  So maybe we
> could use these two converters to create mesh that can be read by
> nek5000.
> http://users.monash.edu.au/~bburn/semtex.html
> Best Regards
> Zhicheng Wang
> Nek5000-users mailing list
