[Nek5000-users] nek5000 compilation
stefanke stefanke at lav.mavt.ethz.ch
Thu Nov 26 10:40:02 CST 2009
What's your OS (operating system)?
On Nov 26, 2009, at 5:25 PM, Tamay Ozgokmen wrote:
> Hi Stefan,
> I am unable to answer this question since I know nothing about C or glibc :)
> I also tried with mpicc (instead of mpixlc) with similar results.
> It supposed to be a system based on Power G4 (similar to IBM P4 and P5) chips with
> IBM compilers, I am not sure what exactly is installed. The website is (if any use):
> http://www.arc.vt.edu/arc/SystemX/
> I have been running various versions of nek5000 on this for several years.
> A makefile that I use to compile an older version of nek500 is attached,
> if it can provide any clues on how to fix this...
> Thanks,
> Tamay
> <makefile.sysx>
> On Nov 26, 2009, at 11:16 AM, stefanke wrote:
>> "/home/ozgokmen/nek5_svn/trunk/nek/chelpers.c", line 1.10: 1506-296 (S) #include file <execinfo.h> not found.
>> It seems like your running on a non-glibc platform. Right?
>> #Stefan
>> On Nov 26, 2009, at 5:05 PM, Tamay Ozgokmen wrote:
>>> Hi,
>>> I put compiler options "mpif77" and "mpixlc" in makenek (below) but it did not go through
>>> (compiler.out attached); any suggestions?
>>> Thanks!
>>> Tamay
>>> #!/bin/bash
>>> # nek5000 build script
>>> # (c) 2008,2009 UCHICAGO ARGONNE, LLC
>>> # source path
>>> SOURCE_ROOT="$HOME/nek5_svn/trunk/nek"
>>> # plug-in list
>>> PLUGIN_LIST=""
>>> # pre-processor symbol list
>>> PPLIST="" # MPIIO BLAS_MXM BG_MXM K10_MXM
>>> # Fortran compiler
>>> F77="mpif77"
>>> # C compiler
>>> CC="mpixlc"
>>> <compiler.out>
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Tamay Ozgokmen
> Associate Professor
> Division of Meteorology and Physical Oceanography
> Rosenstiel School of Marine and Atmospheric Science
> 4600 Rickenbacker Causeway
> Miami, FL 33149-1098, USA
> Phone :  305 421 4053
> Fax      :  305 421 4696
> Email  :  tozgokmen at rsmas.miami.edu
> Web : http://www.rsmas.miami.edu/personal/tamay
