[Nek5000-users] How to make the tools?
stefanke stefanke at lav.mavt.ethz.ch
Wed Nov 25 03:58:05 CST 2009
Are you using the latest repo version?
On Nov 25, 2009, at 10:50 AM, stefanke wrote:
> This is your problem:
>> /usr/bin/ld: cannot open output file OME/bin/prex: No such file or directory
> Check the output of:
>> echo $HOME
> Try to hardwire the 'bin_nek_tools' path in makenek e.g.
>> bin_nek_tools="/home/foor/bin"
> Stefan
> It looks like 'bin_nek_tools' path is not correct
> On Nov 25, 2009, at 10:45 AM, Frederik Folke wrote:
>> Hallo Stefan,
>> first of all thanks a lot for fast answering. I just tested your tip and run:
>> ~/nek5_svn/trunk/tools$ ./maketools prenek
>> But there was an error message:
>> /home/folke/nek5_svn/trunk/tools/
>> Make prenek...
>> make[1]: Entering directory `/home/folke/nek5_svn/trunk/tools/prenek'
>> "gfortran" -o "OME/bin"/prex prenek.o curve.o edit.o build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o xdriver.o  -L/usr/X11R6/lib -lX11 -lm
>> collect2: ld returned 1 exit status
>> make[1]: *** [prex] Error 1
>> make[1]: Leaving directory `/home/folke/nek5_svn/trunk/tools/prenek'
>> make: *** [all] Error 1
>> Here is the maketools script:
>> #!/bin/bash
>> # binary path
>> bin_nek_tools="$HOME/nek5_svn/trunk/tools/"
>> echo $bin_nek_tools
>> # specify your compilers here
>> F77="gfortran"
>> CC="gcc"
>> So you have got an idea where I might have done a mistake??
>> Best regards,
>> Frederik
>> Zitat von stefanke <stefanke at lav.mavt.ethz.ch>:
>>> First of all there is no need to use the MPI-wrappers because all tools are serial programs.
>>> To compile the tools just run:
>>> ./maketools <toolname>
>>> e.g.
>>> ./maketools genmap
>>> hth,
>>> Stefan
>>> On Nov 25, 2009, at 10:02 AM, Frederik Folke wrote:
>>>> Dear Nek developers,
>>>> I just started to introduce myself to your code. Unfortunately I had some problems to
>>>> "make" the tools of the program (prenek, postnek...). I used the existing makefile in the
>>>> nek5_svn/trunk/tools/prenek directory and added the first lines of the maketools script:
>>>> #!/bin/bash
>>>> # binary path
>>>> bin_nek_tools="$HOME/bin"
>>>> F77="mpif77"
>>>> CC="mpicc"
>>>> To start the compilation I typed: make -f makefile
>>>> But I got the following message:
>>>> "mpif77" -c  prenek.f
>>>> prenek.f:89.3:
>>>> 300     CALL SETEQT                                                      1
>>>> prenek.f:198.72:
>>>>     GO TO 300        2
>>>> Warning: Label at (1) is not in the same block as the GOTO statement at (2)
>>>> "mpif77" -c  curve.f
>>>> "mpif77" -c  edit.f
>>>> "mpif77" -c  build.f
>>>> "mpif77" -c  build1.f
>>>> "mpif77" -c  build2.f
>>>> "mpif77" -c  bound.f
>>>> "mpif77" -c  plot.f
>>>> "mpif77" -c  xinterface.f
>>>> "mpif77" -c  glomod.f
>>>> glomod.f:1534.9:
>>>>  ja(2) = w(2,1)                                                           1
>>>> Warning: Array reference at (1) is out of bounds (2 > 1) in dimension 1
>>>> "mpif77" -c  legend.f
>>>> "mpif77" -c  vprops.f
>>>> "mpif77" -c  iolib.f
>>>> "mpif77" -c  subs.f
>>>> "mpif77" -c  zipper2.f
>>>> zipper2.f:1560.20:
>>>>  COMMON /CTMP2/ XP(NXM3),YP(NXM3),ZP(NXM3),RRL(3)                                    1
>>>> Warning: Named COMMON block 'ctmp2' at (1) shall be of the same size
>>>> zipper2.f:2816.20:
>>>> zipper2.f:4640.20:
>>>>  common /ctmp0/ jx(nxm*3),jyt(nym*3),jzt(nzm*3)                                      1
>>>> Warning: Named COMMON block 'ctmp0' at (1) shall be of the same size
>>>> zipper2.f:4639.20:
>>>>  common /ctmp2/ xp(nxm3),yp(nxm3),zp(nxm3),wk(ldw)                                   1
>>>> zipper2.f:4776.20:
>>>>  common /ctmp0/ xcb(2,2,2),ycb(2,2,2),zcb(2,2,2),w(ldw)                              1
>>>> "mpif77" -c  postnek6.f
>>>> "mpif77" -c  screen.f
>>>> "mpicc" -c  revert.c
>>>> "mpif77" -c  crs.f
>>>> "mpif77" -c  mxm.f
>>>> "mpicc" -c  xdriver.c
>>>> "mpif77" -o "OME/bin"/prex prenek.o curve.o edit.o build.o build1.o build2.o bound.o
>>>> make: *** [prex] Error 1
>>>> Hope you can help me.
>>>> Best regards,
>>>> Frederik
>>>> p.s.: Is there existing a "Users Guide" for Nek5000 or is at least the "Users Guide" for
>>>> Nekton v?? helpfull?
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
