[Nek5000-users] How to visualize the result by VisIt
Stefan Kerkemeier kerkemeier at lav.mavt.ethz.ch
Sat Jun 20 12:54:15 CDT 2009
are you using the ASCII output format (param(66) < 0)? I would recommend
to switch to the binary format (param(66) > 0).
For more details see here:
https://nek5000.mcs.anl.gov/index.php/Parameters
Anyway your filetemplate in metadata file seems to be wrong. Try the
following:
filetemplate:  eddy_uv.fld%02d
btw: the '%02d' means that two digits will follow.
hth,
Stefan
王志成 wrote:
> Hi,
> I run the case 2D eddy_uv and have writtten the metadata file
> vis.nek5000 for visualization.
> But the metadata file can't be loaded into VisIt which gives error
> like this: VisIt could not read from the file
> /home/wzc/nek5/examples/eddy_uv/vis.nek5000.
> PS:
> The name of  result file  are:  eddy_uv.fld01 ........ eddy_uv.fld11
> The content in my vis.nek5000 is :
> NEK3D
> version: 1.0
> filetemplate:  eddy_uv.fld%11d
> firsttimestep: 1
> numtimesteps: 11
> and I use executable version of VisIt 1.11.2.
> Regards,
> Zhicheng Wang
> Nek5000-users mailing list
