[Nek5000-users] endian problem
Thu Dec 3 04:29:03 CST 2009
Hi Paul,
Both data and geometry are contained in the restart files. What I meant
was that the binary re2 file was read correctly, but not the restart
files. But yes, I agree, it should not matter -- that's the whole idea
with this if_byte_swap - thing. But anyway, it seems to run with the
slightly older version.
Johan
P.S. Did you see the response from Peake? Looks promising, once I choose
my words carefully in the revised version...
nek5000-users at lists.mcs.anl.gov wrote:
> Hi Johan,
> are you reading two sets of .f0000 files, one w/ geometry
> and one w/ data?
> Do they have different endian characteristics?  (I think
> that shouldn't matter - since endian is determined on a
> file-by-file basis, and the flag set accordingly...)
> Paul
> On Thu, 3 Dec 2009, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> I am trying to start up a job on intrepid now with the newest version of
>> the code, with a resulting endian problem. It seems the code can
>> handle the
>> geometry file correctly but breaks down after reading the restart files
>> with the wrong endian. Is there any new file format that I should be
>> aware of?
>> The output file is attached. Thanks for any tip!
>> Best regards,
>> Johan
>> Johan Ohlsson
>> Department of Mechanics, KTH
>> SE-100 44, Stockholm, Sweden
>> Phone: +46 8 7906876
>> E-mail: johan at mech.kth.se
> Nek5000-users mailing list
Johan Ohlsson
