[Nek5000-users] Three questions
wangzhicheng wangzhicheng at mail.etp.ac.cn
Sat Aug 1 04:00:54 CDT 2009
 Hi,developers
Thank you for your Code. I'm really impressed with nek5000, although I have only known limited information as yet
1 The first question is about an error:
I run the turbJet case and get this errors
 Number of processors:           1
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
  Beginning session:
  /home/wzc/Code/nek5_svn/examples/turbJet/jet.rea
 timer accuracy:   1.1205673E-06 sec
 read .rea file
 byte swap: F   6.543210     -2.9312772E+35
 help:         128           1         600        9372         600        9372
 help:         600         600 -1700420800
  Error: This NEKTON Solver has been compiled
         for      600    10000 elements.
         The data file has dimensions     9372     9372.
call exitt: dying ...
backtrace(): obtained 9 stack frames.
./nek5000 [0x4d132a]
./nek5000 [0x520276]
./nek5000 [0x426cbc]
./nek5000 [0x4313b6]
./nek5000 [0x403aca]
./nek5000 [0x40338c]
./nek5000 [0x61eeee]
/lib/libc.so.6(__libc_start_main+0xf4) [0x7fab919881c4]
./nek5000 [0x4032d9]
At line 388 of file /home/wzc/Code/nek5_svn/trunk/nek/comm_mpi.f
Fortran runtime error: Unexpected end of format string
(3(A,1g13.5,A,/)
2 What I intend   to do is  an accurate simulation of incompressible
turbulent flow  (with heat  transfer)  around cylinders, my question is
:is nek5000 suitable for this simulation?
If it is YES, can I use the mesh generate tools included in nek5000 to create mesh for this case?
I know you are working with Cubit, but I think it is not a free mesh generator.
3 the last: Is there any theoretical manual for me to understand the code ?
I have some back ground on FVM, FEM , right now I study  the book "High-order method for incompressible fluid flow"
Many thanks
Zhicheng
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20090801/37688f8e/attachment.html>
