[mpich2-dev] MVAPICH2 does not work with specified PKEYs.
Rajeev Thakur thakur at mcs.anl.gov
Wed Aug 12 12:37:33 CDT 2009
Mike,
         I have forwarded your note to the mvapich-discuss list, which
is the right list for MVAPICH2 related issues.
Rajeev
  _____
[mailto:mpich2-dev-bounces at mcs.anl.gov] On Behalf Of Mike Heinz
Sent: Wednesday, August 12, 2009 10:40 AM
To: mpich2-dev at mcs.anl.gov
Cc: Todd Rimmer
Subject: [mpich2-dev] MVAPICH2 does not work with specified PKEYs.
My testers are reporting further problems with mvapich2. On a fabric
where the use of pkeys is required, mvapich2 is failing.
1)      The MV2_DEFAULT_PKEY parameter does not appear to be supported
when using mpirun_rsh.
2)      When using mpd and mpiexec, the MV2_DEFAULT_PKEY parameter gets
passed, but then fails. For example:
[root at homer mpi_apps]#  export MV2_DEFAULT_PKEY=0xffff
[root at homer mpi_apps]#  /usr/mpi/gcc/mvapich2-1.2p1/bin/mpiexec
-machinefile /opt/iba/src/mpi_apps/mpi_hosts -n 2 osu2/osu_bw
 [0] Abort: Can't find PKEY INDEX according to given PKEY
 at line 1190 in file rdma_iba_priv.c
rank 0 in job 6  homer.dev.silverstorm.com_33133   caused collective
abort of all ranks
  exit status of rank 0: killed by signal 9
(Note that 0xffff is actually the default PKEY).
A quick saquery reveals that the pkey is, in fact in the table:
[root at homer mpi_apps]# iba_saquery -o pkey -l 1
LID: 0x0001 PortNum:  1 BlockNum:  0
      0-   7:  0x9001  0xffff  0x9002  0x0000  0x0000  0x0000  0x0000
0x0000
      8-  15:  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000
0x0000
     16-  23:  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000
0x0000
     24-  31:  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000  0x0000
0x0000
When I examine ibv_param.c to see what was going on, here is what I
found:
    if ((value = getenv("MV2_DEFAULT_PKEY")) != NULL) {
        rdma_default_pkey = (uint16_t)strtol(value, (char **) NULL,0) &
PKEY_MASK;
And.
    #define PKEY_MASK 0x7fff /* the last bit is reserved */
This makes it clear that mpiexec is doing bad things to the pkey - if
nothing else, the high bit must be set in order for the connection to
have full membership in an  Infiniband partition. Without setting this
bit, a node will only have "limited membership", and limited nodes are
not permitted to talk to each other.
I'm going to try and see if I can quickly put together a patch for you
that fixes the problems with mpiexec - but I'm not sure what the correct
fix is for mpirun_rsh.
Michael Heinz
Principal Engineer, Qlogic Corporation
King of Prussia, Pennsylvania
URL: <http://lists.mcs.anl.gov/pipermail/mpich2-dev/attachments/20090812/82a9342b/attachment.htm>
More information about the mpich2-dev mailing list
