[mpich2-announce] Announcing the availability of mpich2-1.4
Pavan Balaji
balaji at mcs.anl.gov
Thu Jun 16 18:46:16 CDT 2011
A new major release of MPICH2 (1.4) is available for download from
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads
MPICH2-1.4 adds several new features including improved support for
fault tolerance, support for the ARMCI API, and non-collective group
creation functionality. This release also fixes many bugs in the Hydra
process manager and various other parts of the MPICH2 code. All users
using older releases of MPICH2 are encouraged to upgrade to this
version. Please try it out and let us know if you encounter any problems
at mpich-discuss at mcs.anl.gov.
Windows binaries will soon be available from the downloads page.
The MPICH2 Team
Changes in 1.4
# OVERALL: Improvements to fault tolerance for collective
operations. Thanks to Rui Wang @ ICT for reporting several of these
issues.
# OVERALL: Improvements to the universe size detection. Thanks to
Yauheni Zelenko for reporting this issue.
# OVERALL: Bug fixes for Fortran attributes on some systems. Thanks
to Nicolai Stange for reporting this issue.
# OVERALL: Added new ARMCI API implementation (experimental).
# OVERALL: Added new MPIX_Group_comm_create function to allow
non-collective creation of sub-communicators.
# FORTRAN: Bug fixes in the MPI_DIST_GRAPH_ Fortran bindings.
# PM/PMI: Support for a manual "none" launcher in Hydra to allow for
higher-level tools to be built on top of Hydra. Thanks to Justin
Wozniak for reporting this issue, for providing several patches for
the fix, and testing it.
# PM/PMI: Bug fixes in Hydra to handle non-uniform layouts of hosts
better. Thanks to the MVAPICH group at OSU for reporting this issue
and testing it.
# PM/PMI: Bug fixes in Hydra to handle cases where only a subset of
the available launchers or resource managers are compiled
in. Thanks to Satish Balay @ Argonne for reporting this issue.
# PM/PMI: Support for a different username to be provided for each
host; this only works for launchers that support this (such as
SSH).
# PM/PMI: Bug fixes for using Hydra on AIX machines. Thanks to
Kitrick Sheets @ NCSA for reporting this issue and providing the
first draft of the patch.
# PM/PMI: Bug fixes in memory allocation/management for environment
variables that was showing up on older platforms. Thanks to Steven
Sutphen for reporting the issue and providing detailed analysis to
track down the bug.
# PM/PMI: Added support for providing a configuration file to pick
the default options for Hydra. Thanks to Saurabh T. for reporting
the issues with the current implementation and working with us to
improve this option.
# PM/PMI: Improvements to the error code returned by Hydra.
# PM/PMI: Bug fixes for handling "=" in environment variable values in
hydra.
# PM/PMI: Upgrade the hwloc version to 1.1.2.
# COLLECTIVES: Performance and memory usage improvements for MPI_Bcast
in certain cases.
# VALGRIND: Fix incorrect Valgrind client request usage when MPICH2 is
built for memory debugging.
# BUILD SYSTEM: "--enable-fast" and "--disable-error-checking" are once
again valid simultaneous options to configure.
# TEST SUITE: Several new tests for MPI RMA operations.
# Several other minor bug fixes, memory leak fixes, and code cleanup.
A full list of changes is available using:
svn log -r7838:HEAD
https://svn.mcs.anl.gov/repos/mpi/mpich2/tags/release/mpich2-1.4rc2
... or at the following link:
https://trac.mcs.anl.gov/projects/mpich2/log/mpich2/tags/release/mpich2-1.4rc2?action=follow_copy&rev=HEAD&stop_rev=7838&mode=follow_copy
Pavan Balaji
http://www.mcs.anl.gov/~balaji
More information about the mpich2-announce
