[mpich-discuss] Fail to make install MPICH2
李朕 lizhen870704 at 126.com
Sun May 20 08:44:43 CDT 2012
Hi Chan
Thank you for your reply.  I try 64 bit mpich2. It works well. Thank you.
Regards.
At 2012-05-16 19:46:31,"Anthony Chan" <chan at mcs.anl.gov> wrote:
>You CANNOT have identical build and install directories.
>In your case, you have
>build_dir = install_dir = /home/linda/mpich2-install
>Set build directory as ~/mpich2-build, and install directory
>as ~/mpich2-install (set by --prefix as part of configure command).
>A.Chan
>----- Original Message -----
>> Hi,
>> Sorry for bothering you.
>> I encountered some problems during makeing install MPICH2.
>> The error massage is "/usr/bin/install: `lib/libmpich.a' and
>> `/home/linda/mpich2-install/lib/libmpich.a' are the same file"
>> I've attached the error massage file.
>> Thanks.
>> Best Regards,
>> Linda Lo
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120520/3de25b92/attachment.html>
